Phone number changed for a 90 year old
ScottyKernow
HI To Plusnet Tech chaps
Firstly i understand you cannot talk to me about my friends problem but hopefully you will be able to contact him direct, i will direct message his details to anyone who can help, note that for him this is URGENT
No personal info will be posted here
My friend is 94 years old, has plusnet broadband and home phone
When he moved house many years ago he brought his home phone number with him, this has worked successfully since he moved
Over the weekend his phone number has changed without his knowledge, i am thinking this "new" number could be the original phone number for hie new house
I can only assume that BT/Openreach have changed something at the exchange/cabinet
All his family, friends, support workers , doctors, etc etc etc only have his "old" number and this is causing him a lot of stress, not good for someone well into his 90's
Look forward to hearing from you
6 REPLIES 6
MatthewWheeler
Fixes: 480
Re: Phone number changed for a 90 year old
Hi @ScottyKernow
I'm really sorry to hear this has happened to your friend.
If you can drop me a PM with what details you'll have I'll see what I can do
 Matthew Wheeler
ScottyKernow
Hi Matthew
Thanks for your response
Will send details over
RobPN
Fixes: 13
@ScottyKernow
It's possible that his line has been inadvertently swapped with someone else's by a technician working on the cabinet.
What happens if you call his old number - does it ring, and if so is it answered?
ScottyKernow
Hi
I did try ringing his old number but it just rings and rings
Matthew is on the case and looks to be sorting it
Cheers
Fixes: 162
A cross connected line is the most likely explanation for this problem. After the number has been restored your friend should check to see if there are any charged for calls on their account … which they did not make.
Though if it just rings out no matter when you call, it’s possible that there is no phone connected to the line. Many broadband users do not have a phone plugged into the line
If this is going to take time to fix, it should be possible to request that the correct number is diverted to the number presently connected to the property. A tad messy but that can be done in seconds whereas a repair could take days.
ScottyKernow
Good info
Perhaps I'll pop down to see him and call plusnet from there, with him present they will be able yo talk to me
