Cannot scroll Add or Remove Call Features page
kjpetrie
Fixes: 5
I noticed I have an advanced call feature - Caller Display - enabled on my phone, so I went to https://portal.plus.net/member-centre/phone/call-features to check whether I was being charged for it. However, I cannot scroll that page, so I can't see its contents. I have tried both Pale Moon 28.14.2 and Opera 72.0.3815.320, but neither will scroll.
6 REPLIES 6
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: Cannot scroll Add or Remove Call Features page
@kjpetrie  There is no charge for Caller Display.
kjpetrie
Fixes: 5
Thanks. I've found that on the tariff page which is reassuring. However, it doesn't solve the problem I reported - that the page can't be scrolled so users can't use it.
JayG
Fixes: 6
Tried the page in question and it doesn't scroll using either Chrome or Edge on PC, or Chrome on smartphone.
Page seems to be broken at least for you and me - Plusnet may pick this up but unlikely to regard it as much of a priority at the moment. 🤔
gjs1701
I've just had that.  I've tried which Chrome and Edge, but I couldn't see whether my caller display was on or not.
wakeman
I had the same issue but just used the zoom option to reduce the zoom level to about 66% then you can see all the page.
gjs1701
Zooming worked a treat.  Thanks.
