Can I have an update
niges204
Hi
This was closed with no update...
Dear Mr S*****,
Hi there Nigel, Hope you are well.
As discussed, we'll have a look in to this number 03007771038. Seems like this number had the ability to make charges without acquiring a connection and will give you an update as soon as we can.
I apologise again for any inconvenience this is causing you.
If you have any questions then please do not hesitate to contact us via:
Email: http://contactus.plus.net
Phone: 0800 432 0200
Kind regards,
April
[Email notification sent to: niges204*********]
[Sms Message: As discussed, we'll have a look in to this number 03007771038. Seems like this number had the ability to make charges without acquiring a connection and will give you an update as soon as we can.
I apologise again for any inconvenience this is causing you.]
