Call Protect :International Number Blocking Problem
LizMac42
Hi - can anybody help me with this problem.   I blocked all International Calls on Call Protect but then found out my daughter, living in the Channel Islands, had been blocked as an International number.
I took the International call block off but we are getting so many of them - they drive us mad!
Is there any option to keep the block on International calls but to 'whitelist' (exclude her number from the block?)
I have been through the options on 1572 but can't understand most of them so don't know whether they include this option.
Would be immensely grateful for any reply
4 REPLIES 4
HarryB
Fixes: 256
Re: Call Protect :International Number Blocking Problem
Hi @LizMac42,
I believe if you dial 1572 and then select option 4 you should get an option for VIP List.
If you put the block in place against international calls and then add your daughters number to the VIP List, this should override the block for her number specifically.
More information on this can be found here: https://www.plus.net/help/phone/call-features/
I hope this helps.
 Harry Beesley
LizMac42
Thanks ++ for this Harry - I have done what you suggested and let my daughter know so when she phones or messages me I will let you know if it works.
LizMac42
Thanks again Harry - IT WORKED  - my daughter can ring me and all those annoying Internationals have stopped - Bliss!
EmilyD
Fixes: 117
Hi @LizMac42,
Thank you for getting back to us. I'm pleased to hear that @HarryB's suggestion has worked.
Please don't hesitate to get back in touch if there's anything else that we can help with.
 Emily D
