Another caller ID not working
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Another caller ID not working
14-07-2020 5:01 PM
We have noticed that our caller ID is not working having recently moved, we are using the same phone a before that used to work, can it be checked that caller ID is set correctly at Plusnet & your suppliers? This seems to have been a common issue with a few people recently.
Fixed! Go to the fix.
16-07-2020 2:48 PM
Hi @Baldric, the Caller Display feature looks to have not carried over correctly in the Openreach phone system. I've re-added that for you, this should be done within 24 hours at the latest.
16-07-2020 5:23 PM
Thanks, that is now working.
16-07-2020 5:30 PM
Great, thanks for confirming that @Baldric Let me know if you need anything further!
- Home Phone
