Strict Nat Issue
KpLUnREAL
Strict Nat Issue
Port Fowarded All Ports for My xbox and still getting Strict Nat On MW2 .
Heard that you can dmz a xbox and it is by far the easiest and best way to have it setup ! Any help is appreciated ?
16 REPLIES 16
Fixes: 1,484
Re: Strict Nat Issue
What router do you have?
KpLUnREAL
thomson 585 v7 mate  Smiley
Woody3600
If you go into your router settings there should be a designated section for NAT. Also make sure upnp is enabled Smiley
KpLUnREAL
Have Upnp enabled and can't seem to find a nat section mate . Any pointers 🙂 ?
dick:quote
KpLUnREAL
anyone ? Roll_eyes
Toffeegerbil
I have the same router and the same problem.
I cant join other pc games aswell, but the cod strict nat is annoying. Especially when you are paying for 'gaming' broadband.
Upnp is on but i cant find the DMZ section on this router, and forwarding does nothing.
Helppp!
matt_2k34
http://192.168.1.254/cgi/b/publicip/cfg/?be=0&l0=3&l1=0&tid=ASSIGN_PUBL_ADDR
is aparently the link for DMZ - obviously change the 1.254 for the IP of your router Smiley
You can use a CLI to talk to the router, which aparently is needed to get some of the more advanced features out of the thomson.
CLI Manual
*Edit*
These links might also be of use to Thomson users
Toffeegerbil
Thanks for the link to the DMZ matt, i assigned the xbox to it and restarted it, now my nat type has gone from strict to open.
Two problems fixed in a day Cheesy
The community help here is great.
matt_2k34
we do try Wink
Does putting your PC in the DMZ make N:TW work ?
Toffeegerbil
Hmm, unfortunatley it didn't work. :<
What are the drawbacks for having something on the DMZ list?
scootie
Dmz'ing an ip  basicaly turns off the routers firewall for the ip address. its not recommended to do this to pc's.
Also when doing this to a console insure that you have the router setup to give the console a fixed lan ip (most routers call this reserving an ip), as if you leave the router to dchp all the ip's on your network there is a chance your router will hand out the dmz'ed ip to a device its not ment for and put that device at risk
Strat
Fixes: 565
Demilitarized zone, outside of which you have no protection from the nasties on the net as Asbo implied.
matt_2k34
@ Asbo
The thomson router works on MAC addresses, not IP addresses, so regardless of if the DHCP gives out another IP - the rules will still apply to the same machines (provided they connect using the same LAN interface)
scootie
@ matt .
i like to make sure that any one else reading about dmz on this thread knows the full story no matter what router there trying to get a open nat setting on  Smiley
ive only used the thompson for a few days but thinking back it did use mac addresses as i remember trying to get the dam thing to hand my xbox its lucky ip address. 10.0.0.4
