do you need to get to the equipment much
- Full Fibre
- Re: do you need to get to the equipment much
- « Previous
- 1
- 2
- Next »
07-06-2015 4:33 PM
Quote from: buntrob as I don't have the control cable plugged in for the battery pack to tell ONT that the main is disconnected.
Well I am not sure what difference it makes but for the record I do have the control cable connected from the UPS to the ONT and my internet certainly stays on when I switch the power off to the UPS and the battery back up kicks in, the only change is that the green power indicator on the ONT changes to red while it is running on the batteries.
09-06-2015 11:12 AM
13-06-2015 4:35 PM
08-07-2015 10:30 PM
Do they ever run things up to the loft ( 2 storey house) then into a room from above?
if it goes outside is the stuff they use external grade or should i put some conduit up.
Does it matter if the electrical hookup is an apc ups instead of a normal socket.
10-07-2015 10:30 AM
The ONT comes with a small battery backup of its own (just a couple of AA rechargeables) There is some debate as to whether this is just to keep a phone connection alive or if it will also maintain the data connection. The instructions for my ONT say phone only, others have said their data connection stays up if power is disconnected. Either way 2 AAs ain't going to last long so I have mine on a ups which should keep it and the router going 3 or 4 hours.
10-07-2015 1:44 PM
16-07-2015 7:22 PM
Anyone any idea how i could contact the wholesale installer or get him a message as he left a pair of fibre cutters here.
17-07-2015 12:53 PM
17-07-2015 1:38 PM
17-07-2015 1:48 PM
17-07-2015 3:56 PM
17-07-2015 3:58 PM
- « Previous
- 1
- 2
- Next »
- Full Fibre
