Upgrade to 900Mbps from 500mbps - no speed increase
FIXED- Subscribe to RSS Feed
- Full Fibre
- Upgrade to 900Mbps from 500mbps - no speed increas...
- « Previous
- 1
- 2
- Next »
Re: Upgrade to 900Mbps from 500mbps - no speed increase
06-12-2023 12:00 PM
I am now getting 800Mbps plus - whatever Gandalf did has kicked it into action it seems!
06-12-2023 12:29 PM
Do you have a static IP ?
06-12-2023 4:48 PM
@Anonymous wrote:
@Gandalf do you know what the maximum firewall throughput of the "Hub 2" is ?
No idea sorry, @bobpullen may know. ![]()
@MisterW wrote:
Do you have a static IP?
They do, but that doesn't appear to have been the issue, because the connection dropped a few times after the product change completed, updating the speed profile, prior to today.
06-12-2023 4:55 PM - edited 06-12-2023 4:57 PM
@Gandalf thanks for checking the static ip and profile change. I had sort of assumed that the connection would have dropped previously so didn't ask initially. That's very strange that the speed should have increased after the last drop then...
06-12-2023 6:25 PM
It isn't going to bottleneck a ~900mbps wired connection.
- « Previous
- 1
- 2
- Next »
- Full Fibre
