Setting up router
hedkandi
Setting up router
I am trying to set up my own router but can't get it to connect. Is there a list of settings anywhere? The router I am using is a Asus RT-N56U
I tried to copy the settings used on the OneHub but keep getting the error 'can't connect to remote server'
Thanks for any help Smiley
2 REPLIES 2
Fixes: 399
Re: Setting up router
You'll need to configure it's connection details with your PlusNet username and password. This https://www.plus.net/help/broadband/broadband-connection-settings/ gives the details.
Hope that helps.
hedkandi
Thanks - got it sorted now Smiley
