Service unavailable
- Full Fibre
- Service unavailable
Re: Service unavailable
24-08-2010 9:03 PM
jim:quote
25-08-2010 9:42 AM
Cheers, Paul
25-08-2010 1:13 PM
We've got faults raised on all of them and I think Ben's spoken to a couple of you arrange engineer visits to try and find out what's wrong. I've been speaking to BTW and they've not seen other reports so I don't think the problem is widespread so we'll need to see what the engineer can find on the first visit.
Plusnet Technology
26-08-2010 8:19 AM
hope this helps.
Regards
mike.
26-08-2010 9:42 AM
Got a question for you - was your VDSL box powered of for any length of time with you switched to the other router?
Working on a theory here.
Phil
26-08-2010 9:57 AM
From memory no, I may of powered it down and restarted the modem and then connected to the draytek router.
26-08-2010 10:16 AM
Not a problem on any physical connections between the vDSL modem and the exchange.
Tried connection to BT test logins through existing router, through direct connect to vDSL modem via netbook and through spare BT Hub in engineer's van.
Engineer spoke to Wholesale who completely shut off dsl line (dsl sync light went out on modem) and restarted. Problem still persisted after this.
Engineer left, leaving the job marked as incomplete, and wholesale have said they will run tests on line overnight. They may send someone else out eventually.
Interestingly, the engineer noted the fact that he has been seeing this problem all week in Bangor through business connections to BT.
He said that he believes the problem to be at authentication servers; as BT infinity business connections require a login but BT residential connections do not (and he hasn't seen this problem on residential lines).
Because of this, he asked if the residential connection I have to Plusnet runs behind a business connection from Plusnet to BT Wholesale.
He was trying to work out how the same problem that happens to business connections to BT could be happening to residential customers on another provider.
This was the only really useful thing learned from the visit. That this problem has been happening elsewhere in Bangor on BT business accounts.
The sad part was that the engineer said that he had been at one of the business sites from 10 am to 5 pm with no resolution of the fault earlier in the week.
26-08-2010 10:33 AM
26-08-2010 10:37 AM
26-08-2010 10:50 AM
have yet to even enjoy fttc as it never worked
26-08-2010 10:54 AM
Rubber tree plant style, I've got high hopes.
( here's the Spotify link for anyone interested - http://open.spotify.com/track/7d696vk1rICDs54c0ADfol )
26-08-2010 11:02 AM
Quote from: intertree I wish you better luck than I; and who knows, maybe their testing my connection overnight will allow them to suddenly discover where fault is and your engineer will just have to follow a handy step by step guide... Maybe?
hopefully fingers crossed
26-08-2010 12:44 PM
26-08-2010 12:53 PM
Before, when I had the hope of an engineer popping out to fix the problem I was perfectly ok with awaiting assistance. Plus, this is the very reason we're on a trail right? To work out the problems to overcome before running the live service.
But now it seems like nobody knows what the real problem is; which is a little worrying really.
My aforementioned high hopes are beginning to waver it seems...
When it is worked out, can we each be sent a full report? Even if it's likely we won't fully understand it.
26-08-2010 1:53 PM
Using the Netgear , only problem is it can be very slow at connecting but once its connected it works well
Nice to have freinds who have spare routers lying round lol
