Poor FTTP performance
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: Poor FTTP performance
- « Previous
- Next »
17-06-2018 4:19 PM
thanks for the update. clearly the BT tests show something not being right, and poor performance for a FTTP install.
If the team could send any appointment requests to the registered email address my FIL should pick them up.
18-06-2018 12:38 PM
PlusNet were / are going to check today to see if there's a capacity issue on the network.
One other thing you could try is re-booting the ONT to see if that makes a difference. If you have a new style box (combined ONT & BBU) there is a reset pin hole on the left hand side of the unit about one third of the way down. You can see it here (you need to click through to the manufacture's guide).
18-06-2018 12:53 PM
18-06-2018 1:35 PM
thank you for the update.
Its pretty consistent at the moment. Never appears to get above 9mbps which is dreadful for a FTTP which is reporting potential of 40mps+
I guess next steps are engineer or more testing?
18-06-2018 1:37 PM
Many thanks.
I think it is combined - but will check. Maybe able to pop over later tonight or tomorrow and take a look.
cheers
Simon
26-06-2018 1:59 PM
@bmc @MatthewWheeler @MasterOfReality @Gandalf
Many thanks guys for suggestions and help these past couple of week. Openreach attended today and all now looks ok.
The fibres appeared ok, when tested. BT changed the router for one of their Hub5 and things seemed ok but not much better. We put the PN router back on and reran the tests, still not much better. They then plugged their laptop into router and oddly the speed reported was up. We retested the internal PC and *bang* was getting 38mbps download.
When I left much later the speed was reporting 90+mbps which is fantastic - wish I could get that kinda speed - even over the wifi which isn't the best in his house.
So the exact issue - not sure - just seemed to speed up once they plugged in, maybe one of the cables was 'loose' which resulted in poor speed.
I now have a happy FIL.
26-06-2018 2:53 PM
We happy to hear that @bigsimes. Please don't hesitate to get back to us should you need any further assistance.
- « Previous
- Next »
