ONT PON light flashing : new FTTP installation
FIXED- Subscribe to RSS Feed
- Full Fibre
- ONT PON light flashing : new FTTP installation
01-02-2025 4:17 PM
Fixed! Go to the fix.
Re: ONT PON light flashing : new FTTP installation
01-02-2025 4:20 PM
This might help explain
01-02-2025 4:23 PM
Line checked out but the connection to OR failed, so the PON is flashing.
The Fibre circuit hasn't been configured correctly by Openreach/BTw. The installation engineer should have contacted them before leaving.
01-02-2025 4:53 PM - edited 01-02-2025 4:57 PM
'Well done' Openreach (not). How on earth they plan to terminate all fttc by Jan 2027 goodness knows.
I've ordered a MiFi as I have such a low expectation this will be fixed quickly. Can't see OR restringing copper to my house to reinstall fttc. Talk about retrofitting tech after trying to be at the bleeding-edge.
¯\_(ツ)_/¯
01-02-2025 5:21 PM
The LOS light isn't on , so there's a physical fibre connection. It SHOULD just be a matter of the OR engineer contacting DCoE and getting the circuit (re) built correctly.
01-02-2025 5:21 PM
01-02-2025 5:43 PM
Technically that is accurate, but it is the analogue PSTN landline phones ending Jan 2027 not broadband over copper wires.
The migration of broadband from copper pairs to Full Fibre is likely to continue to the early 2030s, at which point the television broadcasts to rooftop TV aerials starts getting switched off - so instead of over-the-air, all TV will be delivered via broadband.
01-02-2025 6:00 PM
I see that BT has a dedicated FTTC phone help line. Maybe Plusnet (as it's in the BT family) could share that?
It wouldn't help, that's BT Retails number,. Your problem needs Open reach and only the ISP can contact them
02-02-2025 10:54 AM
Morning @stevebonline ,
I tried to call you to discuss the current situation with your fault and your order however I can see that you are on a call with another agent at the minute so I will allow them to continue.
Please let us know if you need anything further once you are done.
Thanks, Lex
02-02-2025 6:07 PM - edited 02-02-2025 6:11 PM
I had a discussion with one of Plusnet's managers (CG) who is now coordinating a solution. Plusnet has two issues active for my account.
1) a fault on my fttc. This is wierd as the copper has been removed between the pole and my house (I have a pic of the master socket connected to about a meter of wire pulled through by the engineer when they removed the overhead wires to my house, but cannot see how to upload photo to the thread). No wonder there is a fault!
2) a new order for the fttp which has been installed and checks out (PON flashing) but will not connect to the exchange
What confuses me is that I assume the fttc ( now severed) would have to deactivated by Plusnet/OR and a new build of my account used by OR to activate the fttp.
Mind you I am a complete newbie and putting 2+2 together and most likely making 5.
Apologies for that.
Right now;
- I am being issued a MiFi
- an engineer 'may' arrive on Tuesday to look at the fault. When they see there is no copper from the pole to the house they 'may' reconnect the fttc until the fttp can be sorted
- I 'may' get an engineer to look at the fttp issue but not for another 10 days.
I am helpless, confused and resigned to the fact that I am stuffed. I didn't really appreciate how much we relied on the wifi and BB.
03-02-2025 4:37 PM
- Full Fibre
