Internet a bit flaky :)
- Full Fibre
- Internet a bit flaky :)
13-03-2020 2:15 PM
Guys,
Just wondering if someone could do a quick check of my FTTP connection?
Speed test and general surfing is fine. But some WhatsApp calls and VPN connections into work are dropping (both of which are usually fine).
Probably nothing to do with PlusNet FTTP, but I just wanted to ask.
Thanks.
Re: Internet a bit flaky :)
17-03-2020 7:20 PM - edited 17-03-2020 7:22 PM
Hi @misterbreen,
I'm sorry for the delay in getting back to you on here. I've tested your line and can confirm that the test isn't showing any problems with your FTTP connection at the moment.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTP_SERVICE_0000 | ||||
Description | No Fault in FTTP Service | ||||
Main Fault Location | OK | ||||
Sync Status | Up | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
DP Type | External |
17-03-2020 8:08 PM
Thanks for the confirmation. Thanks for getting back to me.
