FTTC Trial - House move
- Full Fibre
- Re: FTTC Trial - House move
31-03-2011 9:06 PM
01-04-2011 3:50 PM
Your account is clearly flagged to show that you're on the trial so it's just the usual process for house moves: http://www.plus.net/support/customer_service/moving_guide.shtml
01-04-2011 9:32 PM
09-04-2011 9:39 AM
Will I be able to retain my current upload speed (10Mb/s) when I move? I've heard the new Plusnet FTTC products will be limited to 2Mb/s upload.
09-04-2011 9:17 PM
23-04-2011 5:35 PM
On hold until the Fibre Team are back in on Tuesday.
Will the move require a BT visit to remove the FTTC faceplate or can I just take it with me?
26-04-2011 10:09 AM
Your service will be moved like for like, i.e same speeds etc.
Also as far as I know and engineer may need to pop into the house you're moving out of (not always needed but let us check and confirm) and will definitely need to visit at the new one.
26-04-2011 10:13 AM
If someone moves into a house which has had a fibre connection will an engineer visit be needed to enable ADSL
26-04-2011 4:40 PM
The ticket doesn't seem to have been picked up again today and I'm conscious that there are only a few days left until I move. I will have access to both flats for a while after 1st May but could do with this being addressed by the moves team ASAP - is there anything you can do to speed things along?
Regards,
twentythree
27-04-2011 10:11 AM
I've asked one of our provisioning team to look at this for you.
Jojo
27-04-2011 10:15 AM
An engineer shouldn't be needed as the line would just need to be re-jumpered at the cabinet. Although saying that engineers will often still call to make sure it's all working correctly. That said, it shouldn't theoretically need an appointment.
Jojo
29-04-2011 8:13 PM
I think they just fitted a new faceplate because it was part of the normal install. My BT engineer said the home bought filtered faceplates would work OK with FTTC but they had been told to change them anyway.
13-05-2011 6:29 PM
Please can this be remedied?
18-05-2011 9:52 PM
- Full Fibre
