Catch 22 -How to upgrade to FTTP & port phone number to Sipgate without losing existing PN account ?
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: Catch 22 -How to upgrade to FTTP & port phone ...
Re: Catch 22 -How to upgrade to FTTP & port phone number to Sipgate without losing existing PN a
31-03-2024 7:49 PM - edited 31-03-2024 7:53 PM
@daveg6hni wrote:
That's a coincidence I have a Gigaset N300A too so I might come back for the settings if I get stuck
31-03-2024 9:12 PM
I wonder if this 'affliction' manifests (or has manifested) itself within the BT group itself.
10-04-2024 2:45 PM
Well I'm a week away from my supposed upgrade to FTTP and I've had a text from BT to confirm availability for the engineer, but I've heard nothing from PN at all and I have no open tickets
Do PN still use the Ticketing System ?
If not, How do I ask them, or remind them, that I have a static IP that I want to retain
10-04-2024 2:49 PM
I don't think you need to remind them. Your account details remain the same with an upgrade including your static IP. At least mine did !
10-04-2024 2:50 PM
@daveg6hni Your static IP will remain - it is not affected by a product change.
10-04-2024 3:42 PM
18-04-2024 5:24 PM
OK FTTP just installed, working and speed good, but user name in router is different to my existing one and ip not static ?
Spoken to PN and they can't seem to fix it, they get an error when they type in the router serial number into their server and it won't connect using my proper credentials either
They also get an error when they try to add my static IP back in ?
Currently on hold 15mins while they investigate...
18-04-2024 5:36 PM
Well after a few mins more Carl cracked it and all now correct, correct user name & static IP
Good old Carl - Many Thanks
21-04-2024 8:22 PM
OK, so I was upgraded to FTTP on Thursday and it is now Sunday and I want to port my old BT number to A&A...
I can't ring into my old BT number or call anyone from it, but I still have a dial tone ?
Am I safe to request porting or should I wait for my line to go dead ?
21-04-2024 8:25 PM
@daveg6hni Get your porting request in ASAP.
21-04-2024 9:12 PM
Don't delay!
For information, if you have a working phone, dial 17070 on the "old" line while it still has a dial tone and see what number is now assigned. It will "probably" be a "holding" number that you also cannot call.
21-04-2024 9:18 PM
Yes I dialled 17070 and it says it is now a different number !
21-04-2024 9:35 PM
Done it with A&A, I just hope it won't affect my FTTP
a month ago
Can anyone advise please,
I have received an email from A&A saying the porting of my landline number is now complete 26/4/24, however, I have added the settings into my Gigaset N300A, but it says registration failed ?
Also if I dial my landline number I am told "you have chosen an invalid number" and my phone's display says "unallocated number" ?
To me that suggests it is not live yet ?
Also I can log into my A&A billing account, but should I also be able to log into the Control Pages, it wants a different ID that I have not been sent or asked to setup ?
a month ago
It's a while ago that I ported my Sipgate number to A&A, but looking back at my email from 2022, the order confirmation email sent to me at the start of the process (titled "Port number to VoIP (<number>)" had the control account user ID.
From memory I had to do some config in the control account to bring the number up to active.
If you can't locate the email (probably from a couple of weeks ago) then I'd suggest contacting A&A to get the ID
- Full Fibre
