Upgraded to Fibre Extra and Plusnet router is not coping
- Upgraded to Fibre Extra and Plusnet router is not ...
04-01-2021 4:18 PM
Having had nearly perfect uninterrupted internet connectivity and WiFi strength for two years with Plusnet Fibre, I have been rather dismayed to have had a terrible experience since upgrading to the Plusnet Fibre Extra around a month ago. I am now receiving the expected speeds of around 78-79mbps into our home, but sadly the Plusnet Hub One router doesn't seem to be coping with the increased speeds! Since upgrading the only way I can achieve my full speed is by plugging into the router via ethernet. Even when sat right next to the router, my WiFi speeds are only hitting around 30-40mbps, and when using my devices elsewhere in the house (as has been the case for many years) I am lucky if I hit 20...sometimes it only manages 1-3mbps! I have had lengthy phone chats with Plusnet support, and tried all of the suggestions including splitting the bands, changing the channels - and none of them have helped. It is so frustrating to have been upsold to the most expensive package, which clearly Plusnet's router cannot handle. In the meantime, I have ordered a BT Home Hub 6 off eBay to see if that works (thanks to advice on this forum) but surely Plusnet should have a better solution for me?! Anyone else experience the same issues after upgrading to faster internet?
Re: Upgraded to Fibre Extra and Plusnet router is not coping
10-02-2021 4:22 PM
I seem to be having the same issue.
When I had fibre 40/10 I pretty much got the full speed wired , and around 35Mb via wifi.
Since getting extra this week, I get decent speeds wired, however on wifi 5G I'm only getting around 20Mb, and on 2.4G I'm getting around 40Mb?
Can't figure out why.
10-02-2021 5:45 PM
My theory (based on reading other comments on this forum) is that the Plusnet basic router just isn't able to handle the increased internet speeds. I followed the bandwagon and bought a BT Home Hub 6 off eBay and my speeds over WiFi have increased significantly. It must just be a better more powerful router!
10-02-2021 6:05 PM
I've just tried changing the channel for my 5G and that seems to have done the trick , speed nearly tripled to about 62Mb , but it's odd because I had no problems on 40/10 , so assumed the channels wouldn't be an issue, especially 5G.
