Upgarde path - Speed Info required (Please)
- Upgarde path - Speed Info required (Please)
16-12-2015 10:50 PM
Been a Plusnet customer since 2009 on ADSL, moved house and am investigating fibre upgrade. I'm sure Plusnet used to have support 24/7 (going round in circles on portal, grrrrrrrrr...). Phones now only active 'office hours +'. Anyone in S74 postcode on fibre willing to share actual speed. Don't want to rely on 'estimates'.....
Any info gratefully recieved
Message 1 of 4
(627 Views)
3 REPLIES 3
Re: Upgarde path - Speed Info required (Please)
17-12-2015 8:35 AM
Speeds from people in the same postcode area as you will be no indication at all. Someone 400 yards from you will have totally different speeds.
Put your phone number in to http://www.dslchecker.bt.com/adsl/adslchecker.welcome - you will get at least the impacted low speed.
Message 2 of 4
(339 Views)
17-12-2015 1:55 PM
@mikwalker
Try Think BroadBand map at http://maps.thinkbroadband.com/?utm_source=mainsite&utm_medium=navigation&utm_campaign=maps&utm_cont...
Put your full postcode in and then click the option to enable speed test results to see what speed test results people in your immediate area are getting
Message 3 of 4
(339 Views)
17-12-2015 1:57 PM
But bear in mind (also I suppose when asking around) that not everyone choose to pay for the higher speeds and some results may be skewed because the test was performed using a wifi connection.
Quote from: georgelnx Put your full postcode in and then click the option to enable speed test results to see what speed test results people in your immediate area are getting
Message 4 of 4
(339 Views)
