Slow speeds and drop out
- Re: Slow speeds and drop out
- « Previous
- 1
- 2
- Next »
05-11-2021 5:39 PM
I have tried it both wireless and wired and no difference with the quality. The software is as follows:
06-11-2021 3:29 PM - edited 06-11-2021 3:31 PM
Thanks a lot for getting back to us @dartilov
Thanks also for letting us know which firmware your router is running at the moment. It's outdated, so I've popped your details over to our products team will be pushing a firmware update through within the next 5 working days or so.
Tests on the line have not picked up any issues whatsoever, and the engineer notes from the previous appear to show a normal working line. The thing about video conferencing apps, is the over-utilisation of your upload speed, which has a knock on effect on your download speed. If you're using a camera, are you able to lower the video quality slightly?
Also, I'd like to see what speeds your router is receiving from the network, as my tests are showing a download sync speed of 77Mbps. Please follow the instructions below, and send me a photo, covering up all personal information.
1. Ensure your device is connected to the router via WIFI or Ethernet, open up a web browser and type 192.168.1.254 into the URL field.
2. You should now be on your Plusnet Hub One Manager. Select Troubleshooting, then on the sub-menu, select HelpDesk. You'll then be asked to enter the admin password, which can be found on the router itself.
3. Scroll down until you find data rate, send across the values you see if you can.
06-11-2021 4:02 PM
08-11-2021 9:34 AM
Hiya @dartilov, thanks for getting back to us. I'm sorry for the continued issues with your service and for the delay in getting back to us.
Everything is looking all good and testing today again shows no issues. Hopefully once the firmware update is pushed through this could help with any wireless problems but given that you are having issues with your wired connection, it does sound like there is something somewhere.
We can certainly look to send a further engineer and I have updated the open ticket here: https://www.plus.net/wizard/?p=view_question&id=217798090. If you add a reply, let us know and we can pick that up for you.
- « Previous
- 1
- 2
- Next »
