Radius Server graph
FIXED- Subscribe to RSS Feed
- Radius Server graph
13-12-2019 11:17 AM
Could someone from the Plusnet Help Team upload the Radius Server graph as I've noticed that my router keeps disconnecting intermittently. I've only noticed it when I log into my router.
The up and down speeds are great since I upgraded to Fibre Extra. I'm just curious to find out why the router keeps going down
Fixed! Go to the fix.
Re: Radius Server graph
13-12-2019 5:02 PM
Thanks for your post @mexicano,
Of course, please see below:
As you can see, we're not detecting much instability, with just a couple of actual drops in the last 48 hours. Does the chart reflect what you're experiencing?
13-12-2019 9:08 PM
Thanks Oskar.
As I mentioned I've only noticed because I've been logging into the router control panel and I noticed that it reads connected only for a few hours or a couple of days and then it goes back to 0 when it reboots.
I haven't actually been affected by the reboots, my average speed is 64/18 so I'm not complaining 😀
I just wondered if maybe there was something wrong with the actual router and needed replacing? It is 3 or 4 years old?
14-12-2019 8:35 AM
Hi @mexicano,
Thank you for your reply. I'm glad to hear that your speed has been good. The level of drops that we're seeing at the moment is within the limits of normal behaviour for the line, so everything looks to be okay for now. You've currently got our Hub One router, which is our most up to date model of router, and you've had this since mid 2017 so this shouldn't need replacing yet.
14-12-2019 8:38 AM
Thanks. That puts my mind at rest.
