PN Ip Profile with static ip.
FIXED- Subscribe to RSS Feed
- PN Ip Profile with static ip.
14-10-2019 4:51 PM - edited 14-10-2019 4:53 PM
My Bt profile is 77.43 Mbs. Could someone check if my PN IP profile is set to same as Bt. A GEA test would also be appreciated. Thanks
Fixed! Go to the fix.
Re: PN Ip Profile with static ip.
14-10-2019 4:58 PM
14-10-2019 10:38 PM
It still appears not to be. That is why I was asking.
15-10-2019 2:54 PM
Hi @sultan3, thanks for your post.
The connection profile our side is: Connection Profile:Generic Speed 78000
As requested, please find your GEA below:
GEA Test Detail | |||
Circuit ID | NA | Service ID | |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 80.0 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 181.5 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
DP Type | External | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-10-02T14:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 79.9 Mbps | 79.9 Mbps | 79.9 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 848.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-10-15T14:17:57.940+01:00 | 2019-10-15T14:32:57.940+01:00 |
Ingress Code Violation | 0 | 1 |
Egress Code Violation | 0 | 1 |
Errored Seconds | 0 | 1 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Please let us know if you need any further information or assistance.
