Lost connection tonight
- Lost connection tonight
19-10-2021 12:08 AM
Tonight at around 11pm I lost connection, the router is showing me an error of
ppp0 timeout waiting for PADO packets
I turned off the router for 15 min, but on restart the same error has returned
The support bot says the line is OK and the connection details have been re-entered, but still ofline at this time. (just gone midnight)
Message 1 of 4
(486 Views)
3 REPLIES 3
Re: Lost connection tonight
19-10-2021 1:37 AM
I lost connection too. Tried turning off and on and reset but the light stays orange ie fault.
I have started the report problem via text. ie text help your landline to plusnet ,then they test your line. if no fault with line they get someone to call you from 8am to 7pm
Message 2 of 4
(474 Views)
19-10-2021 7:36 AM
Looks like the issue fixed itself around 5 am
Message 3 of 4
(457 Views)
19-10-2021 8:40 AM
Glad to hear that your service is back up and running now @TheFlames1980
@shez1974 I'm sorry to hear that you're still having problems with your service. I've run a test on it this morning which shows it's being affected by a Major Service Outage. Openreach are aware of it and have raised an incident which they're hoping to get resolved today.
Message 4 of 4
(440 Views)
