Fibre extra downstream sync speed dropped
- Fibre extra downstream sync speed dropped
28-07-2018 4:49 PM
Re: Fibre extra downstream sync speed dropped
28-07-2018 5:24 PM
Are these speeds on a wired connection? If not, you would need to repeat them wired directly to the router.
Have a look at http://dslchecker.bt.com/ to see what the Openreach systems think is the acceptable downstream range for your line. If your actual speed is low, you have two options: One is to wait to see if a Plusnet person picks up your post; the other is to report a fault yourself.
To report a fault, run though the checks at https://www.plus.net/help/broadband/connection-troubleshooting/ and report a fault at https://www.plus.net/apps/kbdfaults It takes a bit of your time but costs you nothing, and makes Plusnet aware of your issue, they have to look at it, and gets the issue into the queue for action. Don't use Firefox for the BT speed test as, currently, there is a problem with that browser running that test.
Please let us know how you get on.
28-07-2018 5:58 PM
29-07-2018 7:47 AM
Hopefully Plusnet people will be here today; if not they should be on Monday.
Just one more thought: you have rebooted the router some time since the speed dropped? But don't do it frequently as that can trigger the DLM to reduce your line speed.
30-07-2018 9:41 AM
30-07-2018 12:59 PM
30-07-2018 5:50 PM
Hi @vernon123
I have raised this for you with our suppliers. The DLM profile was capped at 34.2Mbps for some reason, so I have asked them to reset it. This can take up to 48 hours to take effect.
30-07-2018 5:58 PM
01-08-2018 9:38 AM
Still no change yet, I thought the reset may happen overnight.
01-08-2018 2:42 PM
Hi @vernon123
You don't need to do anything your end to take effect, this is all done from the Openreach side. I've checked the Openreach system for you and the job is still ongoing. If you haven't heard anything by tomorrow, please let us know.
02-08-2018 9:40 AM
02-08-2018 12:45 PM
DLM resets can take up to 24 hours so I'll come back and check on this at 3pm for you, I'll be able to see from line tests if it's taken effect and follow things up with you from here.
02-08-2018 1:32 PM
02-08-2018 4:16 PM
Thanks I can see that Dean resubmitted it on Monday but it's obviously not taken effect unfortunately. With that in mind we'll need some engineer intervention.
Can you report a fault for us over at http://faults.plus.net please?
Let me know here when you have.
Adam
02-08-2018 5:26 PM
