Fault raised! (Lower speeds, is a change of plan a feasibility?)
tijara33
Fixes: 6
Good morning. While my recent fault was being fixed the OR engineer thought that he had fixed the fault & applied a DLM reset. When he returned the following morning to complete his work he caused several power interruptions which again lowered the speeds.
These have never recovered & the fault was closed several weeks ago. I've dropped from 45/12 to 33/10. Therefore, if my speeds aren't going to recover I request that I be put on the cheaper tariff (55/10)?
Thanks.
PS I've decided to raise a fault as that might elicit a response. Thanks
19 REPLIES 19
Fixes: 1,602
Re: Fault raised! (Lower speeds, is a change of plan a feasibility?)
Hi @tijara33
From what I can see the broadband troubleshooter found a potential fault and reported this through to our suppliers.
Fingers crossed it's fixed soon. Let us know how you get on over the next day or so.
[edit]
With regards to a cheaper package I'm afraid we can't put you on 55/10 but we can look into moving you to 40/10.
tijara33
Fixes: 6
Thanks, G. Presumably I'll get a call over the next couple of days?
Actually, I meant 40/10 but I'll wait until this fault is finally resolved.
Thanks for your prompt response.
EmilyD
Fixes: 117
Hi @tijara33,
I can confirm that our faults team will give you a call once we've received an update from our suppliers, which should be within the next 24-72 hours.
Once the fault is resolved and our suppliers have confirmed what speeds you'll be able to achieve on the line, we can look into moving you onto the 40/10 package if you'd like.
 Emily D
tijara33
Fixes: 6
Very many thanks Emily, it will be good news to get this fault finally closed.Smiley
tijara33
Fixes: 6
It's now 4 days since my fault was diagnosed & nothing further has happened!! My speeds are now 6 down & 0.2 up! I am paying for this totally unacceptable service. I do realise that OR are ultimately responsible. However, will someone at PN please give them a poke & ask them to extract their digit? Thanks. Crazy
MatthewWheeler
Fixes: 480
Sorry to hear you're still having issues.
Your line is currently testing fine as shown below so you should be seeing better speeds than what you're currently getting
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 45.7 Mbps
Upstream Speed 11.9 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 792.7
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-07-20T11:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 39.3 Mbps 45.6 Mbps 43.4 Mbps
Up Stream Line Rate 11.9 Mbps 11.9 Mbps 11.9 Mbps
Up Time 0.0 Sec 900.0 Sec 893.9 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-08-02T11:15:35.904+01:00 2018-08-02T11:30:35.904+01:00
Ingress Code Violation 0 3
Egress Code Violation 0 0
Errored Seconds 0 3
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Can you carry out a speedtest here and click further diagnostics after the initial result?
 Matthew Wheeler
tijara33
Fixes: 6
Thanks for the update Mathew. Your link https://speedtest.btwholesale.com won't launch in my browser for some reason. I keep getting the "Timed Out" message.
Your speeds are much better than mine that's for sure. When the engineer visited 4 weeks ago after he did the DLM reset & he then caused several disconnections while doing some other work. I also had several more disconnections during the 1st 2 weeks of July. Is it possible that the DLM is causing the problem?
I've run the Btw speed test using my own link & done the further diagnostics. I'm showing 18 down & 9 up. Over to you.
MatthewWheeler
Fixes: 480
Thanks for carrying out the tests.
From what I can see the further diagnostics part didn't complete successfully as I can't see any results.
Can you try again?
 Matthew Wheeler
tijara33
Fixes: 6
I've redone them as requested, showing 6 down & 3 up with a profile of 41/10. I used the exit button to close the test, as requested, but nothing happened so I closed the tab manually. It said that "the tests are inconclusive & I was to contact PN for further assistance" which is happening.
I do hope that this can be resolved, Mathew. I think that the cable joint on the pole outside my house is still causing the problem which was supposedly fixed by the OR engineer 5 weeks ago.
Anyway, all the best, your efforts are much appreciated.
Fixes: 1,602
Apologies if you've been through this already, but is your computer connected to your router using an ethernet cable, and have you tried a different device too?
tijara33
Fixes: 6
Yes it is, as instructed & I've also used the PN hub, it makes no difference. I still don't understand why OR was allowed to close the initial fault 4-5 weeks ago. I had told PN that my speeds still weren't correct but OR closed the fault regardless.
I'm sure that it's still the cable fault on the pole which was corroded. The engineer was just in a rush to get away & appeared not to like PN as a company.
When I reported this at the beginning of the week your colleague confirmed that I had a fault & that I would have an engineer's appointment within 72 hours. We are now well past that deadline so you may well imagine my confusion Gandalf. Undecided
Fixes: 1,602
Thanks for confirming.
Could you reply to this ticket with your availability for an engineer visit?
If you let us know over here once you've done this I'll be happy to book the appointment in for you.
tijara33
Fixes: 6
Many thanks.
I'm available all day tomorrow, Monday afternoon, all day Tuesday & Wednesday afternoon.
Fixes: 1,602
No problems, I've booked you in for Monday afternoon.
