FTTP with a home hub 6
- Re: FTTP with a home hub 6
27-10-2018 2:53 PM
Hi , i am on the plusnet trial for FTTP using the supplied hub one. However wifi can be somewhat intermittent , even with extender etc, so have decided to try a home hub 6. I have found one with the red WAN port, but could somebody please post me a link to how i can set up the BT hub . Apologies , i am sure this has been posted before, but i can only find instructions for hh5 and didnt want to do something that i cant fix( bit of a technophobe unfortunately) thanks for any replies
27-10-2018 3:34 PM - edited 27-10-2018 3:50 PM
BT Smart Hub (6) For FTTC see message 41 here .( Not sure about FTTP though).
https://community.plus.net/t5/Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1415464#M312705
Disable Smart set up , you need to change the details before connecting the dsl lead to the master socket otherwise it will try connecting to BT.
also do not use any strange characters in passwords such as £$^>? etc.
https://www.plus.net/help/broadband/broadband-connection-settings/
https://www.plus.net/help/legal/fttp-faq/
27-10-2018 3:43 PM
Erm! the OP is on FTTP.
I would guess that the setup is as above but then connect the ONT to the Red WAN port. Not sure if anyone else has usedd a Smart Hub on FTTP , so let us know how it goes please.
27-10-2018 3:44 PM
Thats why I stated the instructions are for FTTC
27-10-2018 4:29 PM - edited 27-10-2018 4:29 PM
Apologies, thought perhaps you hadn't noticed.
27-10-2018 6:50 PM
Thank younto everyone , now up and working, and hopefully an improved wifi network
27-10-2018 9:47 PM
You may find that you get the best wireless performance if you separate the 2.4 and 5GHz bands. To do this go into the advanced Wifi settings and in 5GHz settings set the sync with 2.4 to off. This should automatically add -5 to the 5GHz SSID.
