Extemely slow broadband speeds
karenannehowell
Hi, my broadband speed seems to be really slow lately. See latest speed test (attached). Please can you help.
Moderator's note by Mike (Mav): Changed thread title slightly.
2 REPLIES 2
Mav
Fixes: 515
Re: Extemely slow broadband speeds
Moved to it's own thread by request and title changed slightly
Forum Moderator and Customer
Chris
Legend
Fixes: 169
Re: Extremely slow broadband speeds
Testing your line isn't showing any problems, the line is connected back to the cabinet at the full available speed and it's not picking up any problems or errors on the line.
Can you advise if you're testing on a wired or wifi connection?
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 2.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 568.3
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-2M Upstream, Error Protection Off
Time Stamp 2017-03-22T11:45:00
