Ethernet dropping out, local devices connected but no internet?
FIXED- Subscribe to RSS Feed
- Ethernet dropping out, local devices connected but...
09-10-2021 11:12 PM
I'd kind of understand the WiFi going but the ethernet, that's a whole new kick in the ***** from an ISP!
I've checked and replaced all cables and powerline adaptors, all hardware has been checked for driver updates, the router has been reset.
This is beyond a laugh now. Please can somebody help.
Fixed! Go to the fix.
Re: Ethernet dropping out, local devices connected but no internet?
09-10-2021 11:58 PM - edited 09-10-2021 11:59 PM
Sorry to hear you've been having problems
On 16th July your router firmware was upgraded. Does this coincide with the start of the problems?
I've just pushed an incremental update to your router that may help. You'll need to switch it off/back on again to apply it.
Let me know how it goes.
10-10-2021 12:32 AM
Thanks for the quick response. Yes it would seem to coincide with that update, I have switched router off and on again but still having the same issues.
I will try again tomorrow.
10-10-2021 2:25 AM
Thanks @Hiphob
Can you confirm the version number of the firmware you're running? Should display in the footer of the router configuration pages.
10-10-2021 6:04 AM
10-10-2021 10:31 AM
Thanks, let me know should the issue persist.
It would also be useful to know how your network is set-up i.e. what's plugged in where in terms of switches/powerline adapters/extenders etc.
12-10-2021 11:44 AM
