Draytek Vigor 130 not connecting to Plusnet
FIXED- Subscribe to RSS Feed
- Draytek Vigor 130 not connecting to Plusnet
22-12-2018 2:16 PM - edited 22-12-2018 2:18 PM
Hi all
First time poster.
I’ve just received from Amazon a Draytek Vigor 130 VDSL2/ADSL2/2+ Modem. I got this because I’ve set a Plex server up and remote access isn’t working - I use Google WiFi so I believe there’s double NAT’ing going on and I can’t turn it off on the Plusnet hub or on Google WiFi.
This is the device:
https://www.amazon.co.uk/gp/product/B00F9E5LQA/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
As far as I was aware I didn’t need a router for this and it would just connect to the socket and work.
It isn’t.
So, a couple,of questions please
- Do I need a router?
- Is it not connecting because there’s nowhere to add in your Plusnet account details?
If it’s failing because of the second question, is there a way to add your credentials in anywhere because I can’t find it.
Thanks in advance
D
Fixed! Go to the fix.
Re: Draytek Vigor 130 not connecting to Plusnet
22-12-2018 2:23 PM - edited 22-12-2018 2:24 PM
According to the Draytek web site you'll need a router. See the pic here...
https://www.draytek.co.uk/products/business/vigor-130
22-12-2018 2:24 PM
You'll need to set the Google WiFi wan settings to PPPoE and enter your Plusnet username and password
https://support.google.com/wifi/answer/6246630?hl=en-GB
22-12-2018 2:27 PM
Thanks for the quick reply but the image on that page is my setup exactly.
Draytek in to the socket
22-12-2018 2:29 PM
Ok then, as @MisterW says you'll need to set it up for PPPoE.
22-12-2018 2:49 PM
22-12-2018 3:58 PM
Happy to help.
Maybe it's not obvious but Google WiFi IS a router.
