Connection keeps dropping
- Connection keeps dropping
19-10-2021 11:08 PM
Hi
My connection keeps dropping at about the same time every night. At about 10.55 to 11.00 PM my router flashes yellow for a few minutes then turns blue.
I have recently been switching my router off at the mains when not in use to save power. Could that be the reason?
Thanks in advance.
Re: Connection keeps dropping
20-10-2021 9:49 AM
Hi @Nezzac, thanks for getting in touch and I'm sorry to hear you're seeing drops in your connection recently. When testing your connection from this side currently I can see there looks to be an underlying issue showing however the testing our side isn't clear whether the issue is being caused by something internal or external to the property. In which case then, I'd recommend going through the below checks to see if the drops look to persist there after.
Just a heads up also, that the router, our suppliers network and ours are all designed with the intention of the router connection remaining solid and turning the router off daily or from time to time over long periods can adjust things like line settings and actually cause stability or performance issues. Keeping in mind that as routers use very little power it's usually under the £10 mark for the router to be on for a full year.
I'd recommend starting with basic checks here: http://goo.gl/p2tpvL
And if that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Feel free to give us a nudge when in this set-up as we can re-test your connection from this side looking for change and improvements.
24-10-2021 7:15 PM
Hi BD
Thanks for replying. I'm still having the same issue. Every night at about 10.50 the router lights change to orange and then blue and orange and blue for about 10 minutes. It hasn't been touched at all and I'm getting frustrated.
25-10-2021 8:23 AM - edited 25-10-2021 8:26 AM
Good morning @Nezzac
Thanks a lot for getting back to us and I'm sorry to hear that you're still having problems with your connection. Tests on the line are now finding a fault with the service - though the source of the issue is said to be within the customer premise.
It's not clear as to whether you've done the Troubleshooting that my colleague sent through.
Going forward, please have a read through our Troubleshooting Guide to see if you're able to resolve the issue sooner. When testing, please remove the faceplate frssom your Master Socket, and connect your router directly into the test socket which lies behind it. Avoid using any extension cables / sockets too if possible.
Troubleshooting Guide - https://www.plus.net/help/broadband/connection-troubleshooting/
See how you get on, and if the problem persists, head across to faults.plus.net and raise this issue with our Technical Support Team. In the Additional Information section, pop in some dates and times that you'd be available for an engineer visit, our Technical Support Team will then be in touch, though feel free to reach out when you've done it and I'll be happy to get the fault raised with our suppliers.
