Cannot connect to Ubisoft server
FIXED- Subscribe to RSS Feed
- Cannot connect to Ubisoft server
03-02-2022 4:31 PM
Trying to play UNO online using Nintendo Switch but kept getting unable to connect to Ubisoft server. Have tried on my sons Virgin Wi-Fi and it works ok. I am assuming it is a Plusnet issue. Can anyone help?
Fixed! Go to the fix.
Re: Cannot connect to Ubisoft server
04-02-2022 10:38 AM
Hello @Joaniem1109
Thanks a lot for getting in touch and I'm sorry to hear that you're having issues with this. I'm not actually aware of any issues we're having with connecting to Unisoft servers, and I myself have been able to recently, on Plusnet broadband.
It sounds like an easy fix, but if you'd like to try turning your router off for 65 minutes, which will assign a new IP address to your connection, give that a go and let us know how you get on.
04-02-2022 1:08 PM
Hi Adam, thanks for reply. I did as suggested and turned the router off for over 65 minutes. Issue still the same when I try to go to online play UNO on Switch. Am attaching screen print of error message. Thanks Joan
04-02-2022 3:57 PM
Thanks for letting me know @Joaniem1109 and I'm sorry to hear that it didn't work. Are you able to forget your network on your switch? Then try re-connecting to the router?
04-02-2022 4:48 PM
Hi Adam,
Thanks again for your reply.
I deleted the network settings on the Switch and reconnected to the router but still getting the same error message.
Joan
05-02-2022 9:36 AM
That's super odd @Joaniem1109, your connection does appear fine from our end, we don't block or restrict access to specific servers either. Have you contacted Ubisoft for support on this matter?
05-02-2022 3:26 PM
@Joaniem1109 it looks like you have our Safeguard parental control filter enabled. Have you tried temporarily disabling it and restarting your router to see if it helps? It could be that the Ubisoft servers are being blocked.
https://www.plus.net/my-account/safeguard/
05-02-2022 4:02 PM
Hello Bob,
Thanks for the reply. Yes you were right about Safeguard, I have switched it off and UNO is now available for online play.
Thanks again to all at Plusnet Support for your assistance.
Joan
