Can't connect to Google.co.uk or youtube - anyone else?
- Can't connect to Google.co.uk or youtube - anyone ...
Re: Can't connect to Google.co.uk or youtube - anyone else?
25-09-2015 7:09 PM
Quote from: Steff Tried it. Not sure it really happened. Terminal said: "No matching processes were found"
It didn't change anything regarding google/youtube use. But it would be good if another user tried it.
I've just edited the quote slightly.
25-09-2015 7:21 PM
25-09-2015 7:28 PM
We are soon to finish for the evening, though our 24/7 team are still investigating the issue.
Matty
25-09-2015 7:32 PM
25-09-2015 7:34 PM
I couldn't connect with Safari or Firefox, did not try Chrome. I cleared cache in Safari and still same problem, restarted and still could not connect and then now it is connecting again. I feel fairly sure it is a Plusnet problem, rather than MAC, to do with https - in fact I have a feeling I had this happen before when using BT/Plusnet.
25-09-2015 7:38 PM
Both Adam Walker and Ben B are in tomorrow morning. I have asked them to check in on the thread first thing.
Matty
25-09-2015 7:44 PM
In all honesty, not being able to use Google or YouTube is rather a massive deal.
I thought Plusnet would be on this 24/7 until fixed.
25-09-2015 7:48 PM
We've escalated this and we're investigating with Google as to what the cause is but it's not just a simple fix I'm afraid.
25-09-2015 8:01 PM
Thanks.
25-09-2015 8:06 PM
25-09-2015 9:38 PM
25-09-2015 9:52 PM
Affecting Google Drive, Calendar, Google.com, YouTube. Cannot access any of them.
Very let down by ISP.
26-09-2015 12:28 AM
Just tried tethering her iPad to my three mobile phone and Google works fine, when I connect back to PN I can't connect again so definitely a problem at plus.net
26-09-2015 2:37 AM
From what I see DIG for www.google.co.uk gives me a bunch of hosts, ALL OF THEM WITHIN PLUS.NET's NET RANGE. Hmmmmmmmm...
dig www.google.co.uk A
; <<>> DiG 9.9.7-P2 <<>> www.google.co.uk A
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 11667
;; flags: qr rd ra; QUERY: 1, ANSWER: 16, AUTHORITY: 4, ADDITIONAL: 5
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;www.google.co.uk. IN A
;; ANSWER SECTION:
www.google.co.uk. 300 IN A 212.56.71.99
www.google.co.uk. 300 IN A 212.56.71.104
www.google.co.uk. 300 IN A 212.56.71.108
www.google.co.uk. 300 IN A 212.56.71.98
www.google.co.uk. 300 IN A 212.56.71.84
www.google.co.uk. 300 IN A 212.56.71.123
www.google.co.uk. 300 IN A 212.56.71.119
www.google.co.uk. 300 IN A 212.56.71.89
www.google.co.uk. 300 IN A 212.56.71.88
www.google.co.uk. 300 IN A 212.56.71.109
www.google.co.uk. 300 IN A 212.56.71.118
www.google.co.uk. 300 IN A 212.56.71.103
www.google.co.uk. 300 IN A 212.56.71.93
www.google.co.uk. 300 IN A 212.56.71.94
www.google.co.uk. 300 IN A 212.56.71.114
www.google.co.uk. 300 IN A 212.56.71.113
;; AUTHORITY SECTION:
google.co.uk. 172799 IN NS ns2.google.com.
google.co.uk. 172799 IN NS ns1.google.com.
google.co.uk. 172799 IN NS ns3.google.com.
google.co.uk. 172799 IN NS ns4.google.com.
;; ADDITIONAL SECTION:
ns1.google.com. 345600 IN A 216.239.32.10
ns2.google.com. 345600 IN A 216.239.34.10
ns3.google.com. 345600 IN A 216.239.36.10
ns4.google.com. 345600 IN A 216.239.38.10
;; Query time: 399 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Sat Sep 26 01:59:32 BST 2015
;; MSG SIZE rcvd: 447
Doing a DIG @8.8.8.8 gives a totally different IP address:
dig @8.8.8.8 www.google.co.uk
; <<>> DiG 9.9.7-P2 <<>> @8.8.8.8 www.google.co.uk
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 2075
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
; EDNS: version: 0, flags:; udp: 512
;; ANSWER SECTION:
www.google.co.uk. 30 IN A 216.58.208.67
Check out 'whois 216.58.208.67'
get GOOG
Check out 'whois 212.56.71.99'
get Plus.net.
So .... has your proxy google service decided to not play with https?
That's what I'm getting as the error in Safari 7.1.8; could be that your local google-alike doesn't negotiate the cyphersuite properly with Safari.
Hack Solution for me is to change my DNS resolver to 8.8.8.8. Makes an https:// connection to google fine.
I'm unamused at this -- is a recent (like, yesterday) change, and I run my own resolver so getting plus.net services is kinda odd.
Q: Why is there a google-alike service run by Plus.net, and why is it broken?
atb, Lawrence
p.s. for the avoidance of doubt, doing an explicit query at the plus.net DNS resolvers gives me the plus.net google-alike service as well
dig @212.159.13.49 www.google.co.uk A
; <<>> DiG 9.9.7-P2 <<>> @212.159.13.49 www.google.co.uk A
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 37344
;; flags: qr rd ra; QUERY: 1, ANSWER: 16, AUTHORITY: 0, ADDITIONAL: 1
;; ANSWER SECTION:
www.google.co.uk. 111 IN A 212.56.71.154
www.google.co.uk. 111 IN A 212.56.71.166
www.google.co.uk. 111 IN A 212.56.71.176
www.google.co.uk. 111 IN A 212.56.71.159
www.google.co.uk. 111 IN A 212.56.71.174
www.google.co.uk. 111 IN A 212.56.71.155
www.google.co.uk. 111 IN A 212.56.71.170
www.google.co.uk. 111 IN A 212.56.71.144
www.google.co.uk. 111 IN A 212.56.71.187
www.google.co.uk. 111 IN A 212.56.71.165
www.google.co.uk. 111 IN A 212.56.71.185
www.google.co.uk. 111 IN A 212.56.71.177
www.google.co.uk. 111 IN A 212.56.71.163
www.google.co.uk. 111 IN A 212.56.71.181
www.google.co.uk. 111 IN A 212.56.71.152
www.google.co.uk. 111 IN A 212.56.71.148
;; Query time: 24 msec
;; SERVER: 212.159.13.49#53(212.159.13.49)
;; WHEN: Sat Sep 26 02:06:03 BST 2015
;; MSG SIZE rcvd: 301
26-09-2015 7:19 AM
