BT Home Hubs no longer working, and half my upload speed.
FIXED- Subscribe to RSS Feed
- Re: BT Home Hubs no longer working, and half my up...
06-03-2022 11:43 AM
I've been using a Smart Hub Type A for several years now, last night, around 2:30ish am, my Home Hub forgot my username and password.
No biggie, I went in and re-input them and it connected, unfortunately it was around a 4Mb/s download connection, where I had been getting 30+, while my upload was 10 Mb/s which is usual.
I have a spare Smart Hub 2 which I plugged in with similar results. I then tried the Plusnet Router and that gave me a 35 Mb/s download which is more like it, but only 6 Up which is highly confusing.
What on earth is going on?
Fixed! Go to the fix.
Re: BT Home Hubs no longer working, and half my upload speed.
06-03-2022 12:01 PM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
06-03-2022 12:03 PM
@pvy2712 Don't understand why the Type A failed - age? Which Hub do you have connected now?
06-03-2022 12:25 PM
The home hub "could" have failed but I doubt both of them would have.
06-03-2022 12:30 PM
Hub1 or Hub2? Not really a problem, but useful to know. Anyway if you can provide the detail requested below, maybe the Community can help, or PN Help Team staff will pick up.
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
06-03-2022 5:39 PM
About 10:00am this morning my BT Hub 6 stopped working. No internet connection. Contacted Plusnet support and they did all their tests and could not find a problem.
I then fitted a Plusnet router and it connected without a problem. Thinking it maybe a faulty BT Hub6 I set-up a spare one I had and it failed to connect to the internet as well. Stayed on the solid orange light.
I have a Plusnet engineer coming out in a couple of days.
Very strange.
06-03-2022 7:00 PM
@wairds There are no Plusnet engineers, and even if there were they would not come out to troubleshoot a 3rd party modem/router problem so who do you think is coming? If it's a Qube engineer I would cancel the visit immediately as they basically just check that that your modem/router and computer are connected up correctly, pretty basic stuff. If the Hub1 works that's it, no problem.
07-03-2022 1:17 PM - edited 07-03-2022 1:18 PM
,Hello @pvy2712, thanks a lot for getting in touch and I'm really sorry to hear that you're having issues with your router. Uploading a screenshot of your Helpdesk page from your Plusnet Hub might help here, as a GEA test on my end is showing upload speeds of 10Mbps.
Are you still having these issues?
08-03-2022 3:38 PM
Hi @adam945
Yes the plusnet router seems to be working fine now so... no Idea. not tried the other routers but as it's working...
Thank you.
08-03-2022 4:22 PM
I configured the Plusnet router and managed to get that working satisfactorily. Consequently cancelled the BT engineer. Spoke to Plusnet support and they have no idea as to why the BT router wouldn’t work.
08-03-2022 7:21 PM
08-03-2022 7:22 PM
