rDNS change request
jhare1989
rDNS change request
Similar to previous topics, please would you be able change my rDNS on my static IP. I understand the default is ipaddress.plus.net however if I am able to change this to something else then please let me know.
5 REPLIES 5
Fixes: 176
Re: rDNS change request
The default is (certainly used to be**) accountname.plus.com - the usual alternative is ip-address.plus.com
Is yours the former or the latter of the above?
For a good while, we have been asking for the ip-address version to be made the default as that avoids disclosing the user's account name.  What would you like it to be?
To have a change implemented requires one of the staff to pick up this topic ... @MatthewWheeler or @willcutforth
jhare1989
Hi there, it's currently under name.plus.com but I'd very much appreciate if it is changed to my IP. add.
Many thanks
Tags (2)
willcutforth
Fixes: 113
@jhare1989 I have created a ticket on the account for you under https://www.plus.net/wizard/?p=view_question&id=244358423
 Will Cutforth
RealAleMadrid
Aspiring Hero
Fixes: 61
@jhare1989  As you are a new poster on the forum, you may not be aware that when a staff member opens a ticket they are expecting a reply on the ticket (also confusingly called a question) to confirm the change that you want and also for security reasons to ensure you are the account holder.
Login in to the member centre and use this link ....  Plusnet Tickets  to find the ticket.
If you know all this already just ignore my post.😁
SammyM
Fixes: 101
Hiya @jhare1989
Could you reply to the ticket  Will sent you and we will pick this up.
 Sammy M - Sheffield Team
