ccgi cron
- Everything else
- ccgi cron
ccgi cron
13-07-2015 6:58 PM
Hi All,
I thought I understood that plusnet were able to set cron jobs up on the cgi system if I asked nicely via a ticket. I've looked through the various documents and it seems to say that cron was unaffected by the change to Hostopia but I've just had a reply to my request for a cron job that said they don't set them?
If not I'll have to run the cron prompt to hit the script from elsewhere but it would be neater if it ran there (and would also then run at the same time each week).
Any thoughts?
Thanks,
Alistair
Any thoughts?
Thanks,
Alistair
Message 1 of 3
(1,098 Views)
2 REPLIES 2
Re: ccgi cron
14-07-2015 12:16 PM
Hi Alistair,
Direct access to the crontab was removed some time ago when we disabled SSH access. We continued to allow customers to make amendments via ticket up until the migration to Hostopia. There's now only a handful of accounts with access (and even then it's a bit of a hack if I'm honest). Unfortunately, we're not able to set this up for customers who didn't have active crontab entries prior to migration.
Message 2 of 3
(409 Views)
Re: ccgi cron
14-07-2015 2:28 PM
Thanks Bob,
I suspected that would be the case but given the number of out of date pages and forum posts that come up in a search I thought it worth posting here to confirm the current position.
Cheers
Alistair
Cheers
Alistair
Message 3 of 3
(409 Views)
