anyone out there successfully running cakephp in plusnet webspace?
- Everything else
- Re: anyone out there successfully running cakephp ...
14-12-2008 10:27 PM
I'm having some issues getting mine working.
Firstly I was getting apache 500 errors - figured something not working in the url re-writes so I removed all htaccess files
Now i get a script timeout error
Fatal error: Maximum execution time of 30 seconds exceeded in /share/storage/03/on/ontherange/cake/libs/view/view.php on line 641
I notice the php version here is 4.3.10, and cakephp specifies 4.3.2 or higher, so I've a feeling this is gonna perhaps be a non starter.
Anyone had/having similar experience?
Message 1 of 7
(2,024 Views)
6 REPLIES 6
Re: anyone out there successfully running cakephp in plusnet webspace?
15-12-2008 1:51 PM
I'm afraid I don't really know anything about PHP, but isn't 4.3.10 more recent than 4.3.2?
Message 2 of 7
(632 Views)
17-12-2008 10:24 AM
Yes it is. If I get chance I'll see if I can try this out on my CGI space.
Message 3 of 7
(632 Views)
17-12-2008 8:08 PM
thanks guys, but i'm afraid php versions are no exception to the general rules of numbering, so 4.3.1 < 4.3.2
anyway, for the record i did some digging around and have discovered the new trial hosting which at first glance looks great.
php 5 - which is newer than 4 and a proper plesk control panel.
Message 4 of 7
(632 Views)
17-12-2008 9:01 PM
less than an hour later and the site is up and running!
conclusion, to run a cakephp app drop support a line and get yourself onto the new trial webspace.
Message 5 of 7
(632 Views)
19-12-2008 5:03 PM
Quote from: ontherange thanks guys, but i'm afraid php versions are no exception to the general rules of numbering, so 4.3.1 < 4.3.2
True, but 10 > 2, so 4.3.10 is greater than 4.3.2. The .10 isn't a decimal point, it's the revision number. I've not had time to try this yet unfortunately, maybe I will in the new year.
Message 6 of 7
(632 Views)
22-12-2008 4:07 PM
oh yeah, i concur
must've been something else in the configuration of the cgi space which tripped cake over.
Message 7 of 7
(632 Views)
- Everything else
