Where is PHP Error log?
- Everything else
- Re: Where is PHP Error log?
05-03-2014 11:53 PM
Where are PHP error messages written to on the new platform?
Message 1 of 6
(1,592 Views)
5 REPLIES 5
06-03-2014 12:00 AM
PHP error messages are suppressed by default since the information exposed increases security risks. If you want to see errors you need to add
to .htaccess in your code development folder.
php_value display_errors 1
php_value error_reporting 32767
David
Message 2 of 6
(833 Views)
06-03-2014 12:04 AM
Thanks.
Is there any way to write this information to a an error-log file instead of displaying it inline?
Message 3 of 6
(833 Views)
06-03-2014 1:01 AM
i haven't tried this but setting the error_log constant should do that. I think .htaccess will need to contain
You could try with display_errors also set initially as a record of what should be in the log.
David
php_flag log_errors 1
php_value error_log /the/full/path/to/the/error/log_file.log
David
David
Message 4 of 6
(833 Views)
06-03-2014 6:01 PM
Works a treat!
Both in-line display, using display_errors, and writing to a file, using log_errors.
Many thanks.
Many thanks.
Message 5 of 6
(833 Views)
06-03-2014 7:27 PM
That's good to hear. Thanks for the feedback.
David
David
David
Message 6 of 6
(833 Views)
- Everything else
