Reverse DNS needed
Phil_Tyler
Reverse DNS needed
Just been told by the PlusNet helpdesk that there's nothing they can do to amend my rDNS settings!
Is that true?  Is anyone at PlusNet able to change my rDNS?
IP address: 81.174.152.174 currently resolves to gideonit.plus.com and I need it to resolve to box.gideon-it.com
Any help with this is appreciated.
Tags (1)
7 REPLIES 7
Fixes: 406
Re: Reverse DNS needed
NO it isnt! The helpdesk aren't able to, but the staff who frequent this forum are able to raise a request to NetOPS to make the change. I'm sure one of them will be along shortly...
You will need to ensure that your domain has the corresponding A record pointing to your static IP as this will be required before the rDNS can be set.
ClaudiaG23
Fixes: 23
Hi @Phil_Tyler can you pop me a private message with your username please and I can get this sent off for you.
 Claudia Garner
Phil_Tyler
Thank you.  PM sent!
willcutforth
Fixes: 99
I have created a ticket for you @Phil_Tyler Click here and reply and we will action it for you.
 Will Cutforth
Phil_Tyler
Thanks for your help.
Any idea how long this usually takes to get sorted?
MatthewWheeler
Fixes: 480
Thanks @Phil_Tyler
We've raised the requested now and this should go through in the next few days
 Matthew Wheeler
Phil_Tyler
Thank you. 👍
