Reverse DNS change
Wilfred
Reverse DNS change
I recently switched to having a static IP which is working really well.
But noticed my RDNS setting is <username>.plus.net
Feel qute unfcomfortable "leaking" that information; would it be possible to change it to something more anonymous (a random set of numbers and letters)?
Thanks in advance for any help.
Tags (2)
7 REPLIES 7
lasors
Re: Reverse DNS change
did you check out Fixed: rDNS change - Plusnet Community
similar results
Wilfred
Yes, unfortunatly when I navigate to the Help Assistant page I get:
lasors
@Gandalf  may help  - details were in a the post lower down - need to raise a ticket with what you want to change it to so the NetOps team can action it.
 - youraccountusername@plus.com
 - yourIPaddress.plus.com
 - anythingelse.plus.com
Wilfred
Thanks for the answer
Unfortunatly if I follow the link to the wizard I get redirected to exactly the same "We're sorry, but you can no longer ask a question through the Help Assistant." page.
If I could pick a perfect option it would be set to something meaningless like a UUID (or part of a UUID) - for example whatever pops up here:
https://www.uuidgenerator.net/version4
My ip address would probably be ok though.
Fixes: 1,602
Thanks for your post @Wilfred and welcome to our Community Forums.
I've raised a NetOps task to change the rDNS of your static IP to your IP.plus.com
This should be done within the next 3 working days.
Wilfred
Thank you  @Gandalf & @lasors
Really appreciate your help getting this sorted.
I'll hit the "this fixed my problem" button when the change kicks in.
Fixes: 1,602
No problem @Wilfred
We've put through the rDNS change this morning and DNS should propagate within 24 hours.
