Premature end of script headers: index.php
- Everything else
- Premature end of script headers: index.php
11-07-2011 9:05 AM
PlusNet changed the DNS on my account to point to the CGI server. I uploaded some php files to the server (WP Install) and when i visit my website it says
I contacted them over 2 weeks ago but they have still not resolved this issue. Surely it cant take this long to fix a simple config issue, this is a server problem isnt it?
Quote Premature end of script headers: index.php
Message 1 of 3
(2,594 Views)
2 REPLIES 2
Re: Premature end of script headers: index.php
11-07-2011 10:11 AM
I would say no to it been a server problem, I think your problem is with the way you have WordPress Installed on the CGI servers.
Message 2 of 3
(427 Views)
11-07-2011 12:21 PM
As MC says your problem is most unlikely to be a server configuration problem.
The most likely cause is explained in Item 9 of the CGI Platform PHP Upgrade FAQ. You will find links elsewhere in that FAQ to scripts that help to set file permissions correctly. However you might find that following the step-by-step guide posted here helps.
I assume the version of Wordpress you are trying to install is 3.1.4. Version 3.2 won't install without an unofficial/unsupported hack mentioned in the sticky post at the top of this forum.
David
Message 3 of 3
(427 Views)
- Everything else
