New CGI, a few questions: snapshots, DBs, ftp access to old ccgi...force9.co.uk
- Everything else
- New CGI, a few questions: snapshots, DBs, ftp acce...
05-03-2014 7:28 PM
Hi.
I was notified last night that for my user the new cgi space was up and running. Tonight I have started on the challenging road of getting everything up and running in the new environment and have a few questions that may be someone could point me in the right direction to resolve.
1) When was the snapshot taken from my old ccgi...force9.co.uk to restore to the new. Looking at some of the files on the new they date back to October 2013 and there have been a few changes since then
2) Do I still have FTP access to the old ccgi ... force9.co.uk so that I could go through a gradual and accurate migration of old to new if the snapshot in 1) is older than say last Saturday.
I have tried to access it with my old credentials but no success
3) I had 1 Wordpress,1 Moodle and 2 Joomla sites on the old platform. None of them work now. Do I need to go through a process of accessing the old db's via phpadmin (if I still have access), backing up the db's to some local filestore and re-importing via phpadmin to the new.
Any pointers would be much appreciated.
BTW, I checked out one of my perl sites (.pl) at lunchtime on the new platform and instead of it executing, it was public read because of an 'AddHandler' omission in the default .htaccess
....... the air was BLUE
Marku
Marku
Message 1 of 5
(1,435 Views)
4 REPLIES 4
Re: New CGI, a few questions: snapshots, DBs, ftp access to old ccgi...force9.co.uk
05-03-2014 8:04 PM
The "challenge" is meant to be non-existent. Hostopia should have created a dump of your Force9 database and imported it into a new MySQL 5 database on the new server. They should have edited the package configuration files to reflect the changed credentials for access to the new database.
However, since you are a Force9 user - based on experience I suspect database names in the configuration files will probably still contain the old name username_f9 instead of being updated to username_f9_ccgi_username_force9_co_uk. (each instance of username should, of course, be replaced by your Force9 username.) If this is the case correcting the respective configuration files should restore database access for your installed packages.
You will need to view a configuration file to obtain the password for connecting to the new database.
David
David
David
Message 2 of 5
(603 Views)
07-03-2014 2:55 PM
Quote from: marku 1) When was the snapshot taken from my old ccgi...force9.co.uk to restore to the new. Looking at some of the files on the new they date back to October 2013 and there have been a few changes since then
It's possible that the data is old. Let me know if you'd like me to request a recent dump to be ported across.
Quote from: marku 2) Do I still have FTP access to the old ccgi ... force9.co.uk so that I could go through a gradual and accurate migration of old to new if the snapshot in 1) is older than say last Saturday.
As above, you shouldn't need to do this.
Quote from: marku I have tried to access it with my old credentials but no success
We've not done anything to stop customers accessing the old FTP servers.
Quote from: marku 3) I had 1 Wordpress,1 Moodle and 2 Joomla sites on the old platform. None of them work now. Do I need to go through a process of accessing the old db's via phpadmin (if I still have access), backing up the db's to some local filestore and re-importing via phpadmin to the new.
Sounds like your SQL credentials weren't updated. You can get this information from the MySQL Manager in the Control Panel, You'll need to set a new password there. Let me know if you're struggling and I'll help out.
Quote from: marku BTW, I checked out one of my perl sites (.pl) at lunchtime on the new platform and instead of it executing, it was public read because of an 'AddHandler' omission in the default .htaccess
Known problem which should now be fixed. Still missing a Python handler for most but that should be sorted today.
Quote from: marku ....... the air was BLUE
Sorry
Message 3 of 5
(603 Views)
07-03-2014 3:36 PM
many thanks Bob for your response.
I'll raise a ticket to answer your points.
- 1)Essentially I do need a later dump to be ported across
- 2) With a later dump you're right I shouldn't need to manually copy aX
- 3) With a little jiggery pokery I can access the old FTP servers by using the IP address instead of a FQDN (which now points to new)
- 4) It's not the db credentials, it's a little more fundamental, the db is empty which you said will be addressed (in another post)
Marku
Message 4 of 5
(603 Views)
07-03-2014 4:13 PM
Quote from: marku - 3) With a little jiggery pokery I can access the old FTP servers by using the IP address instead of a FQDN (which now points to new)
ccgi.force9.net or cshell.force9.net should work?
Message 5 of 5
(603 Views)
- Everything else
