New CGI Webspace - websites vanished
UncleZen
Thanks PlusNet.
Im working on stuff for a project and its all gone.
Where are my websites?
The URL's no longer work. I do not have permission to access the folder(s) / 403 forbidden.
Ive just jumped through hoops to get the FTP connected and I see a /public folder with sub-folders that look like my stuff might reside there, but when I go there I get permission denied.
Username: unclezen.
Go figure. I'm well annoyed this evening. Angry
11 REPLIES 11
spraxyt
Resting Legend
Fixes: 75
Re: New CGI Webspace - websites vanished
I think this topic, added since your post, explains what's happened and what Plusnet are doing to fix the problem.
David
David
UncleZen
Thanks, I await a solution.
@plusnet how about some decent project management and sufficient testing?
UncleZen
It would be nice if a progress update was posted alongside the "Problems with CGI site migration 4th/5th March? - READ ME FIRST" topic.
bobpullen
Fixes: 316
Your problem should be fixed, let me know if you're still having difficulties. This was an unforeseen error and there's been months of testing. Sorry to have inconvenienced you Sad
UncleZen
Thanks for the update.
All my sites except one are present.
There was a site in a /dev/scgb-new-php folder thats now gone, but I can easily reinstate it so dont worry.
All the files look like they are there (apart for those above) but the sites dont work as the paths are wrong.
UncleZen
An update on paths.
The only site Ive checked so far (I have several test sites) doesnt work as it tries to load data from a data file.
On the old hosting I would verify that the file exists , using php file_exists and give the full path to the file, that would be something like this on the old hosting:
/files/home1/my_username/whatever/path/to/file/filename.dat
On the new hosting, based on the home directory value shown in the Disk Usage > Setup/Environment screen, I'm using:
/services/webpages/c/c/ccgi.my_username.plus.com/whatever/path/to/file/filename.dat
and the file is not found, but the file is present and can be loaded directly into the browser from the address bar.
Have I misunderstood paths?
spraxyt
Resting Legend
Fixes: 75
Quote from: UncleZen
/services/webpages/c/c/ccgi.my_username.plus.com/public/whatever/path/to/file/filename.dat
You need to add /public where I've marked in red in the quote.
David
UncleZen
Thanks, I'll try that out later when I get home.
UncleZen
Tried it out and yes, its working thanks for the tip.
However I have noticed that the one site I have looked at is weeks out of date, I cant tell exaclt how old it only that for me to be absolutley sure its upto date I'll have to re-load all the files from my local copy.
I have loads of work to do to bring these sites back up to date.
@plusnet Sureley a "recent" backup was used before you restored and migrated the data?
bobpullen
Fixes: 316
We can import a more recent copy for you if you like? Failing that, the old database is still accessible from a Plusnet IP using our phpMyAdmin interface.
Yes, that was the intention. Unforeseen delays during the provisioning of this latest batch of accounts has led to some of the data being significantly out of date though. Apologies for the inconvenience. Lack of foresight on our part.
UncleZen
Thanks Bob,
Ive re-uploaded all the out-of date stuff now.
