HTTPS on legacy Freenetname / Madasafish domain
Cnssml
I have had a good read through the various forum posts but can’t find an answer hence my question.
I have a legacy Freenetname / MAAF domain that is still using http. I would really like to move it to https but I don’t know if this is something that can be done on the PN platform.
Any help and advice gratefully received.
regards, Mark
2 REPLIES 2
bobpullen
Fixes: 316
Re: HTTPS on legacy Freenetname / Madasafish domain
Been a while since a question like that has been posed, but I'm fairly certain it's not possible Mark. Even if it is, the certificate wouldn't be issued to your domain name.
If it's something that's important to you, then I'd suggest you consider transferring the domain somehwere else (be mindful that this will impact your email service too though).
Cnssml
Thank you Bob. I suspected that would be the case. I'll go and do some research.
Regards
Mark
