End of contract and moving home
- Everything else
- End of contract and moving home
10-07-2025 5:33 PM
Will be moving sometime in the next couple of months but don't where so can't start a new contract.Told by Plusnet that rolling monthly service would cost in excess of £50.00 per month which I can't afford.
Can anyone help please with suggestions or cheaper options?
Re: End of contract and moving home
10-07-2025 5:39 PM
@Willow6 Why not start a new contract with PN at your current home and then do a 'house move' - I would be amazed if you can't get a Plusnet service at wherever you move to?
10-07-2025 5:42 PM
10-07-2025 5:47 PM
Ah, OK, in that case, sorry, but I have no idea.
10-07-2025 6:13 PM
Could you work with mobile data? I noticed that Three was offering unlimited broadband for (I think) about £20 per month. You would need a decent signal of course. I considered it for someone but the speed wasn't fast enough for a full-time internet connection.
10-07-2025 6:23 PM
A good friend of mine uses a 4G router and he's very pleased with the performance, but it does depend on your usage.
You can get 30 day rolling contracts, used 4g modems are available online, you could sell it once you've finished using it
10-07-2025 7:40 PM
10-07-2025 7:43 PM
11-07-2025 7:40 AM
Signal here is very weak
Does that apply to all networks ? or just the one you are currently using ?
Have a check here https://www.ofcom.org.uk/mobile-coverage-checker
11-07-2025 2:25 PM
Was with 3 which was useless.,. changed to EE which is not much better and non existent at times EE is supposed to be the best for this area and this is supported by the link you sent. ,it does state that good. reception is likely outdoor only
11-07-2025 2:30 PM
Thanks for trying to help but signal here is not good enough.
11-07-2025 2:33 PM
4g modem/routers can have improved wireless performance due to the external antenna compared to a mobile phone.
11-07-2025 2:36 PM
Keep trying to thank Longliner but it keeps ending up in wrong place! Obviously doing something wrong but don't know what.
11-07-2025 2:40 PM
@Willow6 Click the 'thumbs-up' symbol - in grey, at the bottom of the relevant post.
11-07-2025 2:59 PM - edited 11-07-2025 3:02 PM
You're welcome, my sympathies as we had the same problem though we use phone network only. Eventually I bought a few throwaway SIM cards to test each network's signal at home, don't trust the maps. Vodafone was out for a start, no signal at all around here. Three was good until they put their charges skyhigh a couple of years back. Lebara offers good deals but they piggyback on Vodafone so useless.
The EE sim gives five bars but we're not paying EE/BT prices so we're with 1pMobile -- excellent service via EE network with accounts, call charges and duration listed, accounts clearly laid out, no contract, etc. The lo-costs offer data deals but we don't need them.
Hope this helps and good luck!
Mike
- Everything else
