Download webstats folder with wget
- Everything else
- Re: Download webstats folder with wget
07-11-2008 2:10 PM
Hi everyone
I'm about to move a domain name away from the ccgi platform to a new hosting provider.
However I'd like to download the webalizer stats directory before I delete the domain from our account.
I'm using wget 1.8.2 and the wgetgui 1.08c
I've worked out that the webstats folders are located: https://username:password@portal.plus.net/stats-pn/www.domain.com/
However when I try it, I end up getting loads of other folders just filled with robots.txt files, they almost look like other users stats folders
Anyone managed to do this successfully?
Thanks, B
Thanks, B
Message 1 of 5
(2,301 Views)
4 REPLIES 4
07-11-2008 3:14 PM
I've just tried this on a test account and it seemed to work ok. I didn't have the username/password in the URL however, I used flags on wget to set them:
wget -r --user=<username> --password=<password> https://portal.plus.net/stats-pn/<domain>/
Message 2 of 5
(782 Views)
07-11-2008 3:34 PM
I just tried this but the same thing happened.
Loads of directories... www.google.com.br, www.google.co.uk... each with just a robots.txt
Here's the wget log... http://www.highbeeches.plus.com/wgetlog.txt
wget -r --http-user=<username> --http-passwd=<password> -oLOG.txt https://portal.plus.net/stats-pn/<domain>/
Message 3 of 5
(782 Views)
10-11-2008 1:22 PM
That's odd, seems to work fine for me. Maybe it's a difference in the version of wget? I'm using GNU Wget 1.11.4, which is a bit newer than yours.
Message 4 of 5
(782 Views)
10-11-2008 1:23 PM
I just went ahead and did a manual download of all the stats pages instead, rather than using wget
Although I'll try a newer version to see if that works
Thanks, B
Thanks, B
Message 5 of 5
(782 Views)
- Everything else
