Cant log in to upload to webspace
- Everything else
- Cant log in to upload to webspace
Re: Cant log in to upload to webspace
02-08-2008 6:22 AM
Phil
08-08-2008 11:37 AM
Sorry for the late reply, it looks like my colleague fixed this issue for you shortly after you posted. Let me know if you still can't log in via FTP.
14-08-2008 5:20 PM
Cheers
Paul
14-08-2008 5:28 PM
It's worth noting that on PAYG dial-up accounts you can't FTP to the webspace from outside the plusnet network.
18-08-2008 1:47 PM
Response: 530 Login incorrect.
Error: Could not connect to server
Have tried with Filezilla and IE but can't seem to login to upload???
18-08-2008 2:13 PM
18-08-2008 11:05 PM
Have double checked also settings ... looks like I could do with a kick .... errm no kick the webspace ftp thingy instead..
Thanks.
27-08-2008 10:32 AM
I'm getting these problems too, pretty sure I'm using the right settings.
A kick would be appreciated, thanks.
27-08-2008 10:39 AM
Quote from: Aumhur Also have problems logging on to ftp.
I've been able to log in first time to your FTP space, are you still having problems?
[quote=Dynamite]I'm getting these problems too, pretty sure I'm using the right settings.
Same as above, logged in first time no problems.
27-08-2008 3:43 PM
Quote Status: Resolving address of ftp.plus.net
Status: Connecting to 212.159.9.91:21...
Status: Connection attempt failed with "ECONNREFUSED - Connection refused by server", trying next address.
Status: Connecting to 212.159.8.91:21...
Status: Connection attempt failed with "ECONNREFUSED - Connection refused by server".
27-08-2008 4:01 PM
What happens when you try typing ftp ftp.plus.net from a command prompt?
27-08-2008 5:00 PM
However, when I try ftp://ftp.plus.net within firefox, I connect successfully. :L
Quote What happens when you try typing ftp ftp.plus.net from a command prompt?
Quote > ftp: connect: Unknown error number
ftp>
27-08-2008 5:15 PM
Go to Start->Run, type in CMD and hit enter
type: tracert ftp.plus.net
and post the results?
B.
27-08-2008 6:11 PM
Quote Tracing route to ftp.plus.net [212.159.9.91]
over a maximum of 30 hops:
1 * 1 ms <1 ms 192.168.0.1
2 46 ms 37 ms 38 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 38 ms 38 ms 37 ms ge0-0-0-204.ptn-gw02.plus.net [84.92.3.93]
4 39 ms 38 ms 38 ms gi0-2-32.ptc-gw1.plus.net [195.166.129.10]
5 46 ms 52 ms 44 ms pos1-0.pih-cr1.plus.net [195.166.129.250]
6 46 ms 45 ms 45 ms vlan8.pih-gw4.plus.net [212.159.0.30]
7 46 ms 45 ms 45 ms fa0-3-1.fhw-cr02.plus.net [212.159.1.122]
8 52 ms 44 ms 45 ms fhw-lb04.plus.net [212.159.1.146]
9 44 ms 44 ms 45 ms homepages.plus.net [212.159.9.91]
Trace complete.
edit: My problem is fixed, thanks for your help!
29-08-2008 10:21 PM
- Everything else
