Cannot install PhpGedView
- Everything else
- Re: Cannot install PhpGedView
19-03-2010 3:22 PM
After unploading the zip file and unzipping to the server, no probs. I have set the the file and directory permissions as per the advice on the forum and with the help of the script from Gabe (TY for that) but whatever I do the installer is not writing the configuration to config.php, and although about 5 tables are created on humbug, the install stops adding anymore tables to the database. Oddly the installer does a check on config.php and states that it is writeable???
The error message
SQLSTATE 42000: Syntax error or access violation: 1142 INDEX command denied to user 'myusername'@'***.***.*.208' for table 'pgv_messages'Is returned.
It suggests from error code 1142 that I don’t have enough privlieges to perfom such an SQL command. In fact phpMyadmin states "no privileges" under create new database, but I think that is standard on my type of account. Has anyone else had this problem? Or is just a case that PN can alter the privileges to mySQL?
19-03-2010 3:26 PM
19-03-2010 3:39 PM
I'm glad I'm not the only one having problems - see my post at http://community.plus.net/forum/index.php/topic,84399.0.html. Like you, I'm seeing config.php flagged as readable when it appears not - but all my initial tables DO get created so I don't see the error message that you quote. I just get ... nothing! I don't understand Ben's response as PGV just creates its required tables in the default database.
Hope we can get this sorted. I suspect a ticket to PN may be needed. My PAYH site is fine, so at least I can redirect PGV to that for the moment.
Stuart
19-03-2010 6:50 PM
Thanks to Stuart and Ben for the replies.
Ben, I think you misunderstood me. I do know that my account only allows 1 database. As Stuart has correctly said, “PGV just creates its required tables in the default database”.
The install does start to create the tables,
• pgv_blocks
• pgv_favorites
• pgv_messages
• pgv_site_setting
• pgv_users
Then stops with the error message “1142 INDEX command denied to user”.
The config.php is not being written to, so the installer then stops with the above error message and prevents the creation of an admin account as it is attempting to read the database parameters and settings from config.php which only contains the original install default settings. From then on nothing else functions and each attempt to open the program from the browser just returns you to install.php and around we go again. Consequently the gedcom files cannot be loaded and everything is frozen. It cares not if the initial tables that are created in the install are still present in humbug, or if they are dropped.
Editing config.php with the correct database values, passwords and variables, just results in ERROR 256: PGV_DB::createInstance() must be called before PGV_DB::getInstance(). Which is obvious because the tables have not been initially created in the database!
What I don’t understand this version of PGV (4.2.3), has been very happy on my localhost which is running PHP5.3.1 and mySQL server version: 5.1.41.
I have also tried an earlier an earlier version of PGV(4.2.1) a non-PDO release with the same result on PN CGI server. This earlier version is has also been very happy running on my localhost.
I have tried changing the privileges of the PGV files config / install / index.php etc to 710 and 750 but nothing changes. Everything I can find or understand suggests a write permissions problem. Is it possible that SuExec is causing the issue by not allowing full permissions on the PGV files?
PGV requires that Read permissions be set for all files in its directory tree, full Write permissions on the index directory (chmod 777)and also set temporarily for the config.php file during installation.
The problem appears to be very similar to Stuarts http://community.plus.net/forum/index.php/topic,84399.0.html
Should I raise a ticket?
Thanks again.
19-03-2010 7:17 PM
I believe permissions 0750 should be sufficient, with config.php set to 0700, or 0750 at the most.
David
19-03-2010 7:35 PM
Thanks for the reply, but yep been there quite a few times changing to chmod 700 / 750 makes no difference to the problem. The documentation suggests config.php / index directories all set at chmod 777, which we know is no longer allowed on this new platform. My initial thought when this error occured were permissions set on the mySQL side of things, hence the SQLSTATE 42000: Syntax error or access violation, that preceded the 1142 INDEX command ...... error.
I think I shall have to revert back to running it on my localhost here with limited http access to known and trusted souls!
Thanks again, james
20-03-2010 9:56 AM
I have a partial work-around. The problem appears to be with the Apache mod_security. If I include a .htaccess in the PGV root my installer runs successfully.
Could you try this just to confirm or otherwise.
<IfModule mod_security.c>
SecFilterEngine Off
SecFilterScanPOST Off
</IfModule>
This will now run as www.site_name/~site_name~/PGVhome_dir/login.php ; so its not quite there but at least it works after a fashion.
Question 1: How can I use htaccess to redirect to the "non-~" hostname?
Question 2 for PN : Why do I have to disable mod_security? I have never seen this on any other site?
Stuart
(I will add this to my own forum post too)
21-03-2010 9:16 PM
Thanks for the info. apologies for the delay in getting back to you, its been a hectic weekend and only just got around to trying out the .htaccess method.
The bad news it didnt work for me, even after a clean install of PGV basic 4.2.3 and dropping the few tables it had tried to create. The same error was returned and config.php was not updated.
However I think (hope) I am there now.
Another clean install of PGV 4.2.3 basic unzipping it on the CGI server, and then upload the empty table structure to rumpus, the tables exported from mySQL running on my local machine. Set permissions to 750, and I was then able to run the installer, which said the tables were OK and allowed me to proceed.
I could then create an admin id, BUT still the config.php was not updated with the server infos etc. So a quick manual edit of config.php changing the appropriate variables, not forgetting to change $CONFIGURED to true. Set permissions of config.php back to read only then login to PGV as admin and upload the gedcom.
There is for me a write / execute permission issue that causes the installer to stop. I do not think that it is PGV, it has to be PN and the new platform. I am gonna test it for a bit before letting it loose, just in case....Now the next part, getting it back into Joomla.
As far as your question on a htaccess a redirect is concerned, I have used this 301 in the the past
RewriteEngine On
RewriteCond %{HTTP_HOST} ^www.your _first_domain.com$
RewriteRule (.*) http://www.your_redirect_domain.com/$1 [R=301,L]
Thanks for your hel,p good luck, jim
22-03-2010 8:37 AM
Sorry my fix didn't work for you but I was going to suggest you did a table export from you local copy - which you have done.
Thanks for the .htaccess suggestion . I'll give it a try. I'm going to do one more test install using the full PGV install rather than the basic edition and see if that works OK. If it does I'll go with it.
I think I'll raise a ticket with PN regarding the mod_security issue as I have had no feedback on that via this forum yet. There's an old posting on the Sourceforge PGV forum regarding mod_security so thought it worth a try.
I run Joomla 1.5 and that works provided I don't use sh404SEF and the existing .htaccess, so I have turned them off for the time being. I will have to tackle the .htaccess for that at some stage and get it running properly again.
Good luck
Stuart
22-03-2010 8:56 AM
Quote from: stuartp I think I'll raise a ticket with PN regarding the mod_security issue as I have had no feedback on that via this forum yet.
The module isn't installed so the problem must lie elsewhere. I'm afraid I don't know PGV.
Gabe
22-03-2010 9:51 AM
Re: mod_security, as Gabe's mentioned we're not using it on CGI, so it's odd that the .htaccess seems to fix your issue.
22-03-2010 10:03 AM
You are correct about mod_security
This is very strange - I have just taken the mod_security directive out of .htaccess and my site works without it now. I wonder if PN tweaked something whilst I was having issues. The real test will be to do a full reinstall of PGV which I will not be able to do until tomorrow at the earliest. There is one further bug I have found in that the internal contact-me model in PGV does not send any messages to the admin. Its a version of phpmail with a PGV wrapper around it as far as I can make out.
I have just tried your phpwrapper and .htacces but that did not fix it. I can probably do a cludge to point to the ContacMe form I use in joomla as a work-around but its not ideal.
Thanks for all you help to everyone on the forum BTW.
Stuart
26-03-2010 4:51 PM
26-03-2010 5:06 PM
Quote There is one further bug I have found in that the internal contact-me model in PGV does not send any messages to the admin. Its a version of phpmail with a PGV wrapper around it as far as I can make out.
Phpwrapper/.htaccess now working fine. Fixed the PGV Contact mailform by pointing at Gmail's SMTP server rather than using the inbuilt phpmail functions.
Stuart
29-03-2010 11:35 AM
Quote from: hobjohns Ben, did you identify a solution to dazed's problem on checking his mySQL settings?
Yes, and have applied this to your account, you should be able to install the software now. I've not yet been able to determine how the permissions were set incorrectly, it could be at the time the account was enabled the script was incorrect.
- Everything else
