550 Error when trying to delete a file (ftp)
- Everything else
- Re: 550 Error when trying to delete a file (ftp)
08-03-2014 12:56 PM
I seem to have 2 files in separate folders that I cannot delete, when I try, I get a 550 No Such File or Directory error.
The files are zero bytes and are named:
() .dat
() Display Order.dat
The files originated as a result of a bug in some code I was writing eithier in perl or php.
Now I cant get rid of them.
Any ideas how?
() .dat
Any ideas how?
Message 1 of 3
(960 Views)
2 REPLIES 2
08-03-2014 1:52 PM
Have you tried using both an FTP client and the File Manager in the control panel. What are the file permissions set to?
Message 2 of 3
(435 Views)
10-03-2014 4:53 PM
No, I'd only used FTP.
I just used the control panel and its managed to delete them - thanks Bob
Message 3 of 3
(435 Views)
- Everything else
