can send but not recieve , new problem
- Re: can send but not recieve , new problem
- « Previous
- 1
- 2
- Next »
15-12-2011 4:51 PM
ah i see thank you . i dont have a gmail account ,and i must admit , i have no idea what one of those is !
dick:quote
dick:quote
Message 16 of 19
(491 Views)
15-12-2011 7:00 PM
Just set your outgoing server to use the shaw server temporarily whilst you are in Vancouver.
Message 17 of 19
(491 Views)
15-12-2011 7:47 PM
I encounter the same problem in the US and got advice from the forums to change my outgoing server to Roadrunner and problem solved. I have just arrived in Spain and will have to change the setting to Telefonica.
Message 18 of 19
(491 Views)
15-12-2011 9:03 PM
Quote from: MisterW Just set your outgoing server to use the shaw server temporarily whilst you are in Vancouver.
thank you misterW....er.... how would i do that ?
EDIT!!!!!!!
changed smtp to shawmail ,...BINGO, and HURRAHHHH!!!!
it worked , thanks to all that conributed to this post ,,especially misterW which im going to change to SirW to show my appreciation .
thank you .
regards
robert
Message 19 of 19
(491 Views)
- « Previous
- 1
- 2
- Next »
