Setting up outlook
patsy2
Setting up outlook
Hi all
I have recently joined PlusNet from virginmedia, I need to change my outlook address as I will lose this within 90 days, but the email address that has been set up with PN is ridiculously long and I am unsure how I can change it, I notice I have alia and mailbox? How can I change this to a simple email address like I had with Virginmedia, which was made up of a name and a number, I am really confused by it all : (
Many thanks in advance
Patsy
1 REPLY 1
Fixes: 162
Re: Setting up outlook
Hi Patsy,
A warm welcome to the forums.
In what way do you find the PlusNET email addresses ‘ridiculously’ long? They are the same as any other email addresses mailaddress@domain-name.tld
Many ISP’s email addressing is restricted to youaccount@their-domain.com - you get a single email address.
With Plusnet’s Mail service you have your own domain name @youraccount.plus.com - you can then have any number of mailboxes on your domain, something few ISPs offer. Combine the two and you can create...
anyname@youraccount.plus.com
The left hand side can be as short (or long) as you please, whilst the right hand side is what it is and fixed. Did you create a long account name?
