New traffic management hardware
Kelly
Fixes: 9
Re: New traffic management hardware
Hi Pwatson.
This is perfect.  We've got a new DPI box in, which means there could be problems with traffic identification.  We can't test every application signature to make sure it works, so it's important to get decent information about any possible issues you might be seeing.
Can you get reconnected to PCL-AG01 so we can try and see if the application is being identified properly?
Kelly Dorset
Ex-Broadband Service Manager
pwatson
Hi Kelly,
I'll try when I get a chance.  I'm using standard SIP for Sipgate and calls worked first thing in the morning so I think it's unlikely that the new hardware is involved.  Do your systems show when I moved onto PCL-AG01?
Kelly
Fixes: 9
You are currently on ptw-ag04 and connected to it 15:34 23/May/2013.
You were previously on pcl-ag01 and connect to it at 20:51 18/May/2013
Kelly Dorset
jelv
Fixes: 10
If I'm on pcl-ag01 should I be seeing a tracert to one of the DNS servers going to a server in ptn? I thought all four IP addresses went to the same set of load balanced DNS servers within the data centre you are connected to?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bobpullen
Fixes: 316
Good spot Jelv, I'd have thought you'd be routed to the caching servers in City Lifeline. Bizarrely if you trace to the 212.159.6.9, 212.159.6.10 or 212.159.13.49 VIPs then you are routed there. The 212.159.13.50 VIP takes you to Telehouse North though Huh
Edit: Same thing happens on other City Lifeline gateways so I don't think it's anything specific to the new DPI platform.
Anotherone
Champion
Fixes: 21
I'm not on pcl-ag01 atm and all my tracerts to ntp.plus.net go to one cdns server  with one IP address on a particular day/hour/whatever. I'll start another thread as I have a few questions and it would be off-topic here.
Anotherone
Champion
Fixes: 21
Thread regarding tracert's is http://community.plus.net/forum/index.php/topic,115267.0/topicseen.html.
Now on pcl-ag01 since 0647 after power cut in the early hours  Roll_eyes
Is an extra hop involved?
Pings seem ok at present.
Edit: Well I was on pcl-ag01 until I was about to post this and something dropped the PPP - nothing this end - will have to go hopping  Angry
Edit2: Was Plusnet kicking anyone off Gateways at 0730?
bobpullen
Fixes: 316
Quote from: Anotherone
No, not en masse. The disconnect was us though. It was in response to your IP Profile (and subsequently your Plusnet profile) changing.
Anotherone
Champion
Fixes: 21
Thanks for the reply Bob, I'll make further comment in the other relevant thread. Could you please PM the relevant Delta report info & current line speed change details - thanks.
bobpullen
Fixes: 316
Done.
chrispurvey
Hi all,
Tomorrow morning we'll be enabling another one of our gateways (PCL-AG03) to use this new platform.
The switch over went fine for PCL-AG01 and we've moved PCL-AG02 onto the new platform this morning and all seems OK so we don't expect any issues, but if you think you spot any please let us know.
We've also posted a service status.
chrispurvey
On Monday(24th) morning we'll be bringing another one of our gateways (PCL-AG04) to use this new platform.
Again we don't expect any issues, but if you think you spot any please let us know.
We'll also be enabling PCL-AG05 on Tuesday(25th) morning and PCL-AG06 on Wednesday(26th) morning.
chrispurvey
Tomorrow morning(10th) we'll be bringing another two of our gateways (PCL-AG07 & PCL-AG08) to use this new platform.
chrispurvey
Monday afternoon(15th) we'll be bringing another two of our gateways (PTW-AG01 and PTW-AG03) to use this new platform.
As previously we don't expect any issues, but if you think you spot any please let us know.
Aly
Quote from: chrispurvey
I'm on this now Chris and it''s perfect, I didn't know we could switch Gateways sometimes my latency would increase and now I know why.
I am on this gateway now:
C:\Users\Alistair>ping bbc.co.uk
Pinging bbc.co.uk [212.58.251.195] with 32 bytes of data
Reply from 212.58.251.195: bytes=32 time=18ms TTL=117
Ping statistics for 212.58.251.195:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 18ms, Maximum = 18ms, Average = 18ms
C:\Users\Alistair>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.253.67]
over a maximum of 30 hops:
  1    63 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2    18 ms    18 ms    18 ms  lo0-central10.pcl-ag07.plus.net [195.166.128.188
  3    18 ms    17 ms    17 ms  link-b-central10.pcl-gw02.plus.net [212.159.2.18
6]
  4    18 ms    18 ms    17 ms  218.core.access.plus.net [212.159.0.218]
  5    18 ms    18 ms    18 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
  6    18 ms    17 ms    21 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
  7    28 ms    18 ms    18 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  8    *        *        *    Request timed out.
  9    19 ms    19 ms    19 ms  ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
10    19 ms    19 ms    19 ms  132.185.255.156
11    19 ms    19 ms    19 ms  www-vip.cwwtf.bbc.co.uk [212.58.253.67]
Trace complete.
