what speeds should I expect?
- what speeds should I expect?
31-01-2012 5:52 PM
Connection Speed 13126 kbps 445 kbps
Line Attenuation 29 db 5.5 db
Noise Margin 8 db 24 db
moved onto ADSL2 last Friday. download speeds are around 11mb
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
just wondering what I could expect at a maximum DL / UL speeds ( can I also get my upload speed uncapped please )
Thanks for any replies I get
![Cool Cool](/html/@852392E900DCC025F17256C42EA8F698/images/emoticons/cool.gif)
Re: what speeds should I expect?
01-02-2012 2:59 PM
![Crazy Crazy](/html/@224B7702FE50DC681CF42C989FBDC1C1/images/emoticons/crazy2.gif)
01-02-2012 3:12 PM
I can certainly uncap the upstream for you, I'll place a manual order now that should complete tomorrow, from there the upstream should be just over 1mb.
01-02-2012 3:16 PM
I was told I would get around 2mb - 4mb on normal ADSL but normally connected at around 7.2mb with dl speeds of around 800kb/s
so was hoping for something around 15-16mb from ADSL2.
03-02-2012 9:26 AM
Sounds about right for the estimate (you can check your own at http://www.dslchecker.bt.com/adsl/adslchecker.welcome) - that's saying around 5 - 7.5Mb, so given the increase you've seen on ADSL you should see significantly better speeds on ADSL2+.
Interesting difference though, I wonder if a fault has been raised on your line and it's been rerouted (well, changed to a different route) or if you've just improved the internal wiring since the last estimate was done... or it could just be a very good router.
Ah well either way it's good news for yourself
03-02-2012 10:12 AM
Connection Speed 13047 kbps 883 kbps
Noise Margin 6 db 11 db
the above is what my router says at the minute.
I am only 350ish m from my exchange, and as I said in a post above, I was hoping to get a bit higher than 13mb ( dl @ 11.5mb ) but perhaps thats just wishful thinking lol
its the same wiring etc that it has always been, nothing has changed at all. Router is just a bog standard netgear 834g v3 with newest firmware.
the uncapping of the upstream has completed ok, thank you.
03-02-2012 12:03 PM
03-02-2012 12:07 PM
and can I get one
03-02-2012 4:02 PM
If you'd like to go ahead you can raise a ticket or call in, or drop a post in here and we'll sort it out for you
03-02-2012 4:24 PM
03-02-2012 4:50 PM
